Help with Accord wiring?
Old Jan 18, 2004 | 07:25 AM
neilscully's Avatar
Default Help with Accord wiring?
I'm new here, though I've searched a bit to no avail. I'm installing a Compustar remote starter in my fiance's '95 Accord and was hoping someone could help with wiring. I've got the remote starting functions working, but I can't find the power lock and unlock wires under the dash.
I know I can go into the door for them, but I'd rather not for simplicity's sake. I've found several wiring descriptions online for Accords from this generation, mostly saying that the lock wire is a black/white wire in a gray connector above the fusebox "taped to harness" and the unlock wire is an orange wire in "box in blue tape."
I found a black/white wire in a gray connector above the fuse which happened to have an orange wire near it, but both went through the firewall. Didn't look promising, but I tried them anyway with no luck.
Can anyone give me some better insight in where to find these wires? Ideally, I'd like to set it up with driver's door priority as well, but like I said I'd rather go without opening the door for now and I'm assuming that requires opening the door. If anyone has any pictures of the area to find them, that would be incredibly helpful.
-N
Old Jan 18, 2004 | 10:34 AM
Auex's Avatar
Default Re: Help with Accord wiring? (neilscully)
The -trigger lock wires will be in a gray connector that is taped to a harness with blue tape. You have the right colors for the wires. If that is the only one that you have found then try testing the wires to see if they are for the locks. As for the driver's door priority, you will have to five wire the driver's door unlock motor wire, it will be in the harness going into the door( sorry don't know the color off hand).
Old Jan 18, 2004 | 03:02 PM
neilscully's Avatar
Default Re: Help with Accord wiring? (Auex)
Anyone have a better first hand explanation of where to find those wires? That sounds pretty much like the descriptions I already have to work with, but hasn't led me to find it yet.
-N
Old Jan 18, 2004 | 04:06 PM
2FASTDC2's Avatar
There is a connecteror that looks exactly like your OEM speaker harness coneectors that runs into the car through the door loom coming out near the fuse box, it is not connected to anything just taped backto the lom it comes from in blue tape. from there you will have to meter them out, don't remember colors off hand but yo con pop off the switch with the door looks on your door and see the colors there.
Old Jan 18, 2004 | 06:19 PM
brads94accord's Avatar
i couldnt find the wires either so i ended up testing them with a multimeter in the door and just running the wires through some loom from the door sill into the car.
94_EG_Sedan
Audio / Security / Video
Sep 21, 2014 11:51 PM
w211 ryda
Jun 19, 2009 07:18 PM
camogr
Apr 29, 2005 01:00 PM
zertoir
Jun 28, 2004 10:42 AM
Dc2 Powered
Jan 18, 2004 09:51 PM
