HELP! 95 gs-r
Old May 13, 2002 | 09:07 PM
maderfacker's Avatar
Default HELP! 95 gs-r
im isntalling my aftermarket headunit into my 94 gs-r...im lo0king for a wiring diaghram!! THANKS IN ADVANCE!!!
Old May 13, 2002 | 09:26 PM
dc24me's Avatar
Default Re: HELP! 95 gs-r (maderfacker)
Just use a wiring harness, metra part number 70-1720. There's no need to hardwire, unless nobody makes a harness for it.
Old May 14, 2002 | 05:59 AM
i have the harness that cmae with my aftermarket headunit...but i still need to tap into my old harness...rite??
Old May 14, 2002 | 08:24 AM
dasher's Avatar
A wiring harness would not usually come with you head unit, you have to purchase it seperately... go to a car audio store , spend 7-15 bucks , and have a wiring harness you can re-use over and over again if you change your HU.....
Old May 14, 2002 | 08:27 AM
mickey513's Avatar
Default Re: HELP! 95 gs-r (dasher)
Walmart sells one for $7, the exact same one that is sold at Goodguys for $15 but with a different marketing box
Old May 14, 2002 | 08:32 PM
SiClone's Avatar
I'll clear it up for you....
You're better off buying an aftermarket wire harness that connects to the stock Acura one (which plugs into the stock deck). The aftermarket harness has bare wires that you will connect to the harness that came with the deck. With an aftermarket harness, you won't have to hack into your stock wires so you can go back to stock if you decide to do so later...
Old May 15, 2002 | 02:05 PM
THANKS GUYS! now i just cant take off all my panels to get to the hadunit..i took off all of my center cousnle form the armrest to the shifter...i took my left panel off but i cant seem to get my right side off..it lo0ks liek its connected to my whole dash!
alexrsx03
Oct 3, 2007 11:33 PM
streetracerof06
Sep 2, 2005 07:16 AM
Rusty Shackleferd
Jan 25, 2005 11:28 AM
GoodGasMileage
May 21, 2003 08:44 AM
