headunit install
Old Nov 15, 2004 | 01:36 PM
staticrex's Avatar
Default headunit install
1992 Prelude Si. I bought the car with a tape deck with 10 disc cd changer and wanted to change it out as I didn't like it anymore. So I had an older JVC cd headunit sitting around and started putting it in. I bought a universal connecter from Walmart and connected all wires, the wireing diagram I have shows that I did it correctly.
When I first plugged in the unit the antenna would go out and in, the headunit would come on and then immediatly show see you and turn off. It does not light up at all when car is turned on, and nothing show on the display. I can hit the display button and the time will come on and then immediately shut off.
Any help is appreciated.
Old Nov 15, 2004 | 06:47 PM
Auex's Avatar
Default Re: headunit install (staticrex)
Sounds like the radio's accessory fuse is blown, or the wire didn't get hooked up. The fuse should be in the underdash fuse box.
Old Nov 15, 2004 | 11:41 PM
fried's Avatar
id advise checking the wiring again.
i thought i had it right definitely, and couldnt work it out, until i just decided to get over myself and recheck. one wire was wrong, and it fixed all my probems.
Old Nov 16, 2004 | 11:51 AM
staticrex's Avatar
Default Re: (fried)
Thanks I will give it another shot today. I checked over the wiring twice but I will go over it again and also check the fuses. Thanks for the help.
Mike
Freckles
Audio / Security / Video
Dec 19, 2011 12:11 PM
Darkray16
Apr 20, 2006 11:41 AM
crxdriver
Aug 23, 2002 07:11 AM
jkn1515
May 20, 2002 09:11 PM
