Head unit installation on a 93 240sx...issues
Old Feb 4, 2007 | 01:43 PM
zuich2ID's Avatar
Default Head unit installation on a 93 240sx...issues
OK i bought a new sony head unit a little while ago and got the wiring harness and wired it up correctly and connected it to the vehicle and nothing happens. It dont turn on or anything. I checked and replaced ALL the fuses and still nothing. I got the deck itself tested and it works. I also fixed up some crappy wiring on the car itself. Oh its a 93 240sx SE. I am totally clueless on how to get this to work. Info is greatly appreciated. Thanks.
Old Feb 4, 2007 | 03:50 PM
JSPECSIR's Avatar
Default Re: Head unit installation on a 93 240sx...issues (piccilo2)
did you plug in the antenna? nissan harnesses dont have grounds, so the radio grounds through the antenna or better yet you ground it to the metal in the dash.
Old Feb 4, 2007 | 04:41 PM
fcm's Avatar
fcm
Old Fart
Most Nissan's oem radio harness plug does not contain a ground lead, the stock HU is grounded through the chassis.
However, I bet the adapter harness you got has a black ground lead in it, and you connected the HUs ground to it, and that's why it does not work.
You can just connect the HUs ground to the chassis, if you use the stock mounting bracket and pocket, [some custom work needed, depending on HU you have] you will get chassis grounding, [I would still ground the HU lead to chassis.
This may help... http://www.installdr.com/Insta...5.pdf
Although the ant. will supply a ground for the HU it is not the proper way to ground a HU, it is also not the way an ant. works, the ant. cable needs to be grounded at both ends for it to be properly shielded, at the base of the mast and at the HU, [receiver], your Nissan probably also has that "we want to be different" Nissan ant. plug instead of the standard motorola ant plug, so you are using an ant. adaptor. 94
Old Feb 4, 2007 | 05:18 PM
B18C_EJ8's Avatar
Don't most of those cars have factory amps??
Old Feb 4, 2007 | 05:27 PM
zuich2ID's Avatar
thanks for the info, ill try that stuff out tomarrow when i get off duty. thanks
Old Feb 4, 2007 | 05:55 PM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Don't most of those cars have factory amps?? </TD></TR></TABLE> About 25% of the ones I have done did have factory amplified speakers yes. grills have ACTIVE on them.
A definite possibility. 94
Old Feb 9, 2007 | 02:21 PM
zuich2ID's Avatar
well thanks for the chassis info, it worked...put the ground wire up to it and bam it worked. appreciate it.
acardboardllama
Jul 11, 2013 10:28 AM
RedHurricane
Audio / Security / Video
Jan 31, 2011 09:51 PM
1nsoman1ac
Sep 22, 2009 07:05 PM
Fuster_Cluck
Jul 14, 2008 08:20 AM
pprowler6
10
Jul 23, 2007 09:33 PM
