got a question about volts?
Old Dec 10, 2002 | 10:05 AM
93civdx's Avatar
Default got a question about volts?
ok. i'm pretty sure i have figured out how to wire my 12 type r so that i can get the most of it. its a 4 ohm speaker so i don't think that i can wire it to 2 ohm right? i just bought the mrd m300 from alpine and on the box it says that at 14.4 volts it pushes more power than at 12 volts. how do i go about setting it to 14.4 even if i can. by the way this in a 93 civic dx 4 door. any help is greatly appreciated.
Old Dec 10, 2002 | 10:43 AM
infinkc's Avatar
Default Re: got a question about volts? (twolf)
when the car is on its at ~14.4 volts thats when youll have peak power
when its off its about 12.2 volts
The m300 needs to see 4ohms, so leave your sub where its at. 2ohms will run that amp too hot and then cut off
Old Dec 10, 2002 | 11:14 AM
93civdx's Avatar
Default Re: got a question about volts? (infinkc)
thanks man. do you think that the m300 is good enough to make the type r sound good?
Old Dec 10, 2002 | 03:53 PM
B18CivicEJ's Avatar
yeah. that amp should be enough. man. its a great mono amp. plus that amp has all the computer amp settings. make sure you have it set correctly or you wont get full sound from it.
Old Dec 10, 2002 | 07:12 PM
TurboBumblBee's Avatar
Default Re: got a question about volts? (EvoTeg325)
that amp can go down to 2ohms.. check out http://ecominet2.alpine-usa.com/pls/...in=10&p_more=y
you will get more power out of it at 2ohms then you will at 4ohms
Old Dec 10, 2002 | 08:41 PM
twogengsr's Avatar
Default Re: got a question about volts? (95CivicEX)
yea the m300 NEEDS to see a 2 ohm load and it also likes a hu with 4 volts of output voltage also 14.4 isnt a voltage setting on the amp it what your amp should be at when your car is running
Old Dec 11, 2002 | 09:14 AM
93civdx's Avatar
Default Re: got a question about volts? (twogengsr)
thanks ya'll. i know that it can see a two ohm load but from what i read i don't think that i can wire my sub to make the amp see a two ohm load. please correct me if i'm wrong. i'm new to this and i have read alot about it. thanks for the help.
thatasiankidtony
Audio / Security / Video
10
Sep 12, 2007 03:07 PM
.David
Apr 16, 2005 04:20 PM
brickonwheels
22
Jan 15, 2004 05:08 AM
vtec-outlaw
Mar 2, 2002 11:19 PM
Jan 31, 2002 10:43 AM
