got a ORION amp...
Old Jul 7, 2003 | 06:35 AM
basshead's Avatar
Default got a ORION amp...
but i cannot find any specs on the darn thing, its the big red one HCCA 250 i believe, 2 channel, is it too powerful for my system?
my friend had it powering his whole set, kicker subs, mb quarts and punch mids and it was suck! couldnt even turn upo the damn thing....
and tuning is hard cause no specs on the net and no manual....
specs:HCCA250G4 2-CHANNEL 800 WATT COMPETITION AMPLIFIER
2 x 50 @ 4 Ohm
2 x 100 @ 2 Ohm
2 x 200 @ 1 Ohm
2 x 400 @ .5 Ohm
1 x 200 @ 4 Ohm
1 x 400 @ 2 Ohm
1 x 800 @ 1 Ohm
Variable Low-pass 45Hz to 5kHz, variable high-pass with INTELLi Q 10Hz to 10kHz, 10dB of boost with INTELLi Q, remote gain capable, selectable AUX out
doesnt seem so powerful now ive found the specs, what do you think?
can i use this 2 channel amp to power my wntire system?!
one sub and 4 mids? thanks
Modified by newbster at 3:45 PM 7/7/2003
Old Jul 7, 2003 | 04:03 PM
basshead's Avatar
ill just look out for distortion
i will be powering 2 mb quarts, kicker comp vr and toyota speakers with it...
Old Jul 8, 2003 | 01:06 PM
str8cyko's Avatar
Default Re: got a ORION amp... (basshead)
it really depends on your setup and the way you wire it up. make sure your existing speakers will handle the power. orion makes a good amp and is of high quality. to prevent distortion, don't wire your speakers in too low an ohm.
Old Jul 8, 2003 | 02:54 PM
nsxxtreme's Avatar
Default Re: got a ORION amp... (cycocivic)
That Orion amp is a very good amp. I would not use it to run an entire system. Use it for sub duty only. Bridge it and wire you subs in parallel to get the lowest possible impedence you can. This is what that amp was designed to do. It is what they used to call a cheater amp.
Old Jul 8, 2003 | 05:08 PM
basshead's Avatar
hmm, sub amp alone, it seems a waste to use one sub....how much you think it will put out to one sub at 4ohms? i have a kicker comp vr and the bass at 200rms was great, when my friend was using the ORION he could not turn up the bass on the amp! it was freaking loud! i kinda wanted it for mid amp but oh well
ill try and get a matching sub and install it, thanks
Old Jul 8, 2003 | 06:19 PM
vteg's Avatar
New User
Default Re: (basshead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by basshead &raquo;</TD></TR><TR><TD CLASS="quote">hmm, sub amp alone, it seems a waste to use one sub</TD></TR></TABLE>
It is only 800 watts. Little amp.
Old Jul 8, 2003 | 06:41 PM
basshead's Avatar
not to me, ive run a 40 watt punch once
Old Jul 8, 2003 | 08:31 PM
vteg's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by basshead &raquo;</TD></TR><TR><TD CLASS="quote">not to me, ive run a 40 watt punch once </TD></TR></TABLE>
I did not realize that was you.
Old Jul 8, 2003 | 09:25 PM
nsxxtreme's Avatar
Default Re: (vteg)
Jomo
I hope these are real questions and not just a waste of bandwidth.
The HCCA amps Orion made were not designed to run at 4 ohms. The were designed to drive very low impedences.
Old Jul 9, 2003 | 06:40 AM
basshead's Avatar
why would this not be a real question?
low impedence means less than 4ohms? why? is it easy to wire one sub to less than that? i don't get the whole ohms thing....
Old Jul 9, 2003 | 08:00 AM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by basshead &raquo;</TD></TR><TR><TD CLASS="quote">why would this not be a real question?
low impedence means less than 4ohms? why? is it easy to wire one sub to less than that? i don't get the whole ohms thing....</TD></TR></TABLE>
You can wire one sub so it will have an impedence lower than 4 ohms, but only if it is a dual voice coil sub. You will not get any lower than 4 ohms with a 4 ohm single voice coil subwoofer. Either hook it up bridged to that amp and be happy with your 200 W or ad more speakers and extract the power out of the amp that it was designed to put out. I would hook up two 4 ohm dual voice coil subs all in parrallel to this amp.
Allurian
Audio / Security / Video
19
Jan 1, 2009 09:30 PM
Pworld
Jul 16, 2004 10:18 PM
SHystrdyGSRtdy
Jun 25, 2004 06:11 PM
MestizoRacer310
Oct 28, 2002 04:45 PM
