front speakers
Old Dec 5, 2007 | 04:28 PM
mrxlazy's Avatar
Default front speakers
since ive owned my car, ive been getting scratching noises from my speakers. i took out my head unit and secured the wires better and put everything back. now i have no music out of my front speakers. my rears play music and my sub is functioning correctly. the head unit i have came with my car so i have no clue about the wiring. audio pros chime in and help me out
Old Dec 5, 2007 | 04:59 PM
94civcpe's Avatar
maybe a wire came loose while you were reinstalling your radio
Old Dec 5, 2007 | 05:37 PM
fcm's Avatar
fcm
Old Fart
Default Re: front speakers (mrxlazy)
Ditto the above.^^^
Also, MM&Y of car, make and model of HU?
How many amps do you have, sub amp only, or something for the high-pass speakers also? 94
Old Dec 6, 2007 | 06:23 AM
mrxlazy's Avatar
i have 2 amps and 1 sub, my cars a 95 rs integra, and my head unit is an alpine,
Old Dec 6, 2007 | 09:41 AM
mrxlazy's Avatar
can some audio pros pm me
Old Dec 6, 2007 | 10:50 AM
CivicPride97's Avatar
Default Re: (mrxlazy)
If you have 2 amps and one sub then im guessing the other amp might be for your speakers........do you have any RCAs running out of the pre-outs of your radio. Do you have a digital multimeter. You can try checking for Ohm load which should read some where in the neighbor hood of 4 ohms. Or if you have 12v battery try popping the speaker by using the Negative and Positive wire of the speaker your testing and tapping the wire to the battery negative and positive. Usually since its an aftermarket radio the front right speaker should be grey-grey/black wire and front left is white-white/black wire ............
Old Dec 6, 2007 | 11:38 AM
fcm's Avatar
fcm
Old Fart
One amp for the sub, what is the other amp connected to, front, rear or both sets of speakers?
What is the model of the amp and the Alpine HU?
What is the make and model of the front speakers?
If your front speakers are "amped" and were "noisy" before, it could be the RCAs were lose and have come compleatly disconnected when you pulled the HU to fix the wiring 94
BoOsTiN Dc2
Audio / Security / Video
Apr 20, 2005 05:20 PM
Luserkid
Sep 24, 2004 04:19 PM
RIOredKIRKLANDcrx
May 14, 2004 07:38 AM
swatdog
Nov 4, 2003 02:26 PM
Racer X
11
Nov 13, 2002 08:27 PM
