front speakers?
well on the 99 eclipse spyder
the front speakers dont seem to work
and the rear speakers blow out if i turn the volume over 24/25ish
and i have to pop the head unit face off and put it back on
and the system is fine again.
im thinking i need a whole new system.
can someone suggest
type of subwoofers
front speakers
amp
and head unit.
thanks a lot
can someone suggest
type of subwoofers
front speakers
amp
and head unit.
thanks a lot
well i cant really make suggestions cuz i havent heard alot of the things you have mentioned but i can tell what i have i have 1 12" Planet Audio comptetion and a MA audio amp 800w 450rms and i really like it and for my front stage i have phase linear coaxial and hi-freq. tweeters and i think that it sounds good. the bass is clean and crisp and will put out alot of vibration when needed to but as far as what you are looking for i would upgrade your front and rear speakers first then get into the subs because if you have shitty speakers then there is no point for the bass because you can hear anything but that so its really up to you on how you go about that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by letsstophere »</TD></TR><TR><TD CLASS="quote">well on the 99 eclipse spyder
can someone suggest
type of subwoofers
front speakers
amp
and head unit.
thanks a lot</TD></TR></TABLE> It sounds like you have some wiring problems, [a short someplace] or you have blown speakers
What kind of Hu is it, [make/model] how much higher above 24/25ish will the volume go? Do you have amp/amps, what kind of speakers are they?
94
can someone suggest
type of subwoofers
front speakers
amp
and head unit.
94
