first alarm install help
Old Apr 28, 2010 | 02:43 PM
Autointeg's Avatar
Default first alarm install help
okay got a crimestopper 2 way pager alarm, ran all the wires correctly and alarm works, but the part where i dont get is the power door lock and unlock, the info i got was running - unlock to green and white and - lock to green and red, i get no power, do i need to run relays? i know for the ign and starter kill you need one. help on this please by the way i have a 95 civic lx with working pdl's
Old Apr 28, 2010 | 03:07 PM
b20_driven's Avatar
Default Re: first alarm install help
I didnt run a relay to my doors. Maybe you have the wires reversed?
Old Apr 28, 2010 | 03:09 PM
b20_driven's Avatar
You got the wires wrong, yo.
Green/White is to lock
Green/Red is to unlock. Go try that and see if it works.
Old Apr 28, 2010 | 03:57 PM
Autointeg's Avatar
kay, so then it should work after that right? i'll have to check in the morning when i get back from work. thank you!
Old Apr 28, 2010 | 04:00 PM
Autointeg's Avatar
bythwway i got the wiring sheet from commandocaralarms.com
Old Apr 28, 2010 | 04:47 PM
fcm's Avatar
fcm
Old Fart
http://www.bulldogsecurity.com/diagr...16309&MakeID=3
The door locks should still have worked, just backwards, are you sure you got the correct green/red and green/white leads.
You do not need relays, Honda/Acura power door locks are polarity reversing, ground at rest and already have the relays, [power door lock control unit] and are low current neg.(-) trigger. 94
Old Apr 28, 2010 | 05:07 PM
Autointeg's Avatar
the wires hook up to the white plug on top of the fuses in the fuse box, theres one green/red and one green/white
Old Apr 28, 2010 | 05:53 PM
b20_driven's Avatar
Yeah, it should work. they got the wires backward on ya.
Old May 2, 2010 | 03:55 PM
b20_driven's Avatar
DId it work?
B-Rabbit20
Aug 18, 2015 01:08 PM
bearboy80
11
Jun 7, 2015 12:54 PM
98greensi
Audio / Security / Video
Sep 28, 2010 08:58 AM
NVturbo
Feb 16, 2006 02:17 PM
Maverik4k
Sep 21, 2004 09:36 PM
