Factory head unit amp install...
Old Nov 10, 2006 | 04:16 PM
Miracle's Avatar
Default Factory head unit amp install...
2003 Ford F-150
Installing an aftermarket amplifier, using a line level converter to hook up the RCA's to the factory head unit...
According to the instructions that came with the converter, you hook up the wires to one of each the left and right channel speaker wiring from the factory head unit.
I did that, and still no signal. The amp is getting power, and all settings are dialed in, such as gain, output mode, channel output and such.
RCA's are connected correctly... but still no signal. Any ideas?
I hooked up the converter according to the instructions, to each of the + and - leads for the left front and right front wires.
Any suggestions?
Old Nov 10, 2006 | 04:57 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and all settings are dialed in, such as gain, output mode, channel output and such.</TD></TR></TABLE>
How did you make your adjustments properly when you had no audio???
Anyways.. Are there adjustment pots on the converter? Are they turned up?
Are you sure you tapped the right wires?
Old Nov 10, 2006 | 05:01 PM
Miracle's Avatar
Default Re: (B18C_EJ8)
I had set the settings on the amp to their "optimum" settings when I had it in my old car, and have not touched them.
There are gain controls on the converter, and they were in the middle of the dial
And I tapped the wires, according to the converter's instructions, and the wiring diagram for the truck.
Old Nov 10, 2006 | 05:06 PM
B18C_EJ8's Avatar
Well if you say you've tapped the right wires in the truck, then I believe you.
Bad converter maybe?? :shrugs:
Old Nov 10, 2006 | 09:41 PM
02 accord's Avatar
Default Re: (Miracle)
Any adjustments on the converter other than gain?
Old Nov 12, 2006 | 05:51 PM
cdx280's Avatar
sounds like you're tapping into the RF and LF speakers at the radio?
you need to tap into those speaker wires after the factory amp you have.
if the amp is for a sub, then you only need to get the signal from one channel (either LR or RR speaker)
hope this helps...
ShawnbobHatch
Audio / Security / Video
10
Sep 9, 2010 06:16 PM
Jakemmarsh
12
Mar 23, 2010 03:57 PM
kharned08
Honda Civic (2001 - 2005)
Dec 4, 2007 06:51 PM
VTEC_PRODUCTION
14
Nov 9, 2007 08:42 PM
CRXican
Apr 8, 2002 10:43 AM
