Extra Siren
Old Jun 3, 2005 | 07:22 AM
skrewdriver88's Avatar
Default Extra Siren
I bought an extra alarm siren to hook up to my Python 460HP. My question is should i just mount it under my hood like where my other one is or in the back of the car. I was wanting it to go in the back of the car but i don't know of a good spot to mount it to. So please help me or at least give me some ideas.
TIA
Old Jun 3, 2005 | 07:39 AM
fcm's Avatar
fcm
Old Fart
Default Re: Extra Siren (skrewdriver88)
I have installed a few under the bumper clip, remove clip, carve out some of the Styrofoam, install siren, reinstall clip. 94
Old Jun 3, 2005 | 12:16 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Get a DEI (Viper) 515R back up siren. Then you won't need to hide it. Plus, even if the wire's been cut, it'll ring for a good 3-5 minutes on it's reserve battery.
Just adding a siren won't do **** if someone breaks in and unplugs the alarm brain out of your car.
Old Jun 3, 2005 | 12:33 PM
AlpineInstaller's Avatar
Default Re: Extra Siren (ScareyH22A)
Install the alarm INSIDE the car. It's insanely loud in a confined cabin and hide it well. REAL WELL.
Old Jun 5, 2005 | 02:30 PM
Alright guys i think i found a spot on the back of the bumper area but i was wondering what would be the best way to run it from the back of the car to the brain without going under the car so the wires aren't outside. I didn't really see any good spots to drill or any spots where there are already wire holes so what would be the best way to go about this.
thanks
Old Jun 5, 2005 | 02:49 PM
Auex's Avatar
Take the siren and mount it with screws under the trunk on the opposite side as the muffler. Then remove screws, enlarge the holes the screws were in, drop a bolt in each of the holes and mount the siren with the bolts.
On my civic there were some blank grommets behind the bumper cover, I don't remember where exactly. Run the wire into the car there and run it to the alarm. Be sure to fuse this siren seperately from the one under the hood with a 3 amp fuse. That way if someone shorts one of the siren's out the other will still be going off.
Old Jun 5, 2005 | 04:06 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">Alright guys i think i found a spot on the back of the bumper area but i was wondering what would be the best way to run it from the back of the car to the brain without going under the car so the wires aren't outside. I didn't really see any good spots to drill or any spots where there are already wire holes so what would be the best way to go about this.
thanks</TD></TR></TABLE> If you pull the rear trim out of the hatch you will see the grommet for the license plate light wires, run it with them. 94
Old Jun 7, 2005 | 09:47 PM
Default Re: Extra Siren (fcm)
Run the wires inside the car. If you take out all of the "carpet" on the side in your trunk area, you will see a large hole with rubber flaps that allows water to evaporate out of your trunk area (should be on the left). You can run the wires through there with no drilling/cutting and everything will still be hidden.
Old Jun 8, 2005 | 08:11 AM
fcm's Avatar
fcm
Old Fart
Default Re: Extra Siren (AlpineInstaller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlpineInstaller &raquo;</TD></TR><TR><TD CLASS="quote">Run the wires inside the car. If you take out all of the "carpet" on the side in your trunk area, you will see a large hole with rubber flaps that allows water to evaporate out of your trunk area (should be on the left). You can run the wires through there with no drilling/cutting and everything will still be hidden.</TD></TR></TABLE>Not a good way to do it, the wire will keep the "flaps" open allowing water to splash in, as I said there is already a grommet for the license plate light wiring going out the back of the car. 94
Old Jun 8, 2005 | 10:41 PM
Alright so i know how im going to run the wires and i bought an inline 3 amp fuse but my only question now is do i just splice the siren wire and connect it there or do i some how connect both positive wires to the connecter where it plugs into the brain?
TIA
Old Jun 10, 2005 | 08:12 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">Alright so i know how im going to run the wires and i bought an inline 3 amp fuse but my only question now is do i just splice the siren wire and connect it there or do i some how connect both positive wires to the connecter where it plugs into the brain?
TIA</TD></TR></TABLE>I would install a relay, using the alarms siren output to control the relay, then wire both sirens to the relay, [driving both sirens directly off the alarm may do damage to the alarm brain] and to be safe you need 3 fuses, one for power for the relay and one for each siren. 94
Old Jun 11, 2005 | 11:05 PM
Could you please draw me a diagram of how to hook up the relays and all the other stuff. I am not good with electronics.
thanks
Old Jun 12, 2005 | 07:41 AM
fcm's Avatar
fcm
Old Fart
I need to know what the polarity is on the siren output, is it a pos. (+) or a neg. (-) output, go here http://www.the12volt.com click on relays under basics, to understand how relays work, also check everything under car security, lots of other good "stuff" there also, then if you have a question feel free to IM me 94
Old Jun 21, 2005 | 12:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">I need to know what the polarity is on the siren output, is it a pos. (+) or a neg. (-) output, go here http://www.the12volt.com click on relays under basics, to understand how relays work, also check everything under car security, lots of other good "stuff" there also, then if you have a question feel free to IM me 94</TD></TR></TABLE>
when i click on the link it brings me to yahoo and i also tried typing it in but it brings me to yahoo also so i don't know if it doesn't work or if its just my old *** computer
Old Jun 21, 2005 | 01:06 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skrewdriver88 &raquo;</TD></TR><TR><TD CLASS="quote">or if its just my old *** computer</TD></TR></TABLE> It must be, If I click on the link, or the link of your quote of me it works, Log out of H/T and then try it. All I can do is tell you how its wired, but I need to know what the alarms siren output polarity is, pos. or neg. 94
Old Jun 22, 2005 | 10:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> I need to know what the alarms siren output polarity is, pos. or neg. 94</TD></TR></TABLE>
It is at my house but what am i looking for is it on the box or on the siren.
thanks
Old Jun 23, 2005 | 09:31 AM
fcm's Avatar
fcm
Old Fart
thanks</TD></TR></TABLE> It will be in the wiring diagram, the siren can be used both ways, [pos. (+) or neg. (-) "trip"] but to tell you how to wire the relay, I need to know what the siren output from the alarm is, [probably neg. (-)] 94
Old Jun 23, 2005 | 09:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> It will be in the wiring diagram, the siren can be used both ways, [pos. (+) or neg. (-) "trip"] but to tell you how to wire the relay, I need to know what the siren output from the alarm is, [probably neg. (-)] 94 </TD></TR></TABLE>
There is no wiring diagram but coming from the siren is just the positive and negative wire and the soft chirp loop wire.
Old Jun 23, 2005 | 10:51 AM
fcm's Avatar
fcm
Old Fart
There is no wiring diagram but coming from the siren is just the positive and negative wire and the soft chirp loop wire.</TD></TR></TABLE>I mean the wiring diagram for the alarm 94
Old Jun 26, 2005 | 01:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">I mean the wiring diagram for the alarm 94</TD></TR></TABLE>
im not sure if this is what you are talking about but there is a positive and a negative coming from the brain to the siren and the alarm system that i have a Python 460 HP.
TIA
Old Jun 27, 2005 | 10:53 AM
bump
Old Jun 27, 2005 | 01:06 PM
fcm's Avatar
fcm
Old Fart
TIA</TD></TR></TABLE>Sorry I took so long to get back to you,I had to go to the shop to access directed for the install manual, anyway, the output is 12V+, it does not say how many amps, so I would guess it's around the same as the input one, [15A], but to be safe, use a relay and wire it this way......
86- to ground
85- from the alarms siren output, [brown]
87- from a 12V+ constant source, [fused]
87a- not used
30- to red wire of both sirens
The black wires from sirens go to ground. 94
Old Jun 29, 2005 | 10:31 AM
Thanks
Old Jun 29, 2005 | 04:06 PM
fcm's Avatar
fcm
Old Fart
YW........ Let us know how it works out. 94
Old Jul 7, 2005 | 11:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Sorry I took so long to get back to you,I had to go to the shop to access directed for the install manual, anyway, the output is 12V+, it does not say how many amps, so I would guess it's around the same as the input one, [15A], but to be safe, use a relay and wire it this way......
86- to ground
87a- not used
The black wires from sirens go to ground. 94</TD></TR></TABLE>
Just one more question before i install it. where you said "from the alarms siren output, [brown]" do i just take the wire and unplug it and connect it to the 85 and then get a wire and connect 85 to the spot were the siren output was before?
