electronic control panel???
Old Mar 16, 2004 | 09:22 PM
SUB-0 H23's Avatar
Default electronic control panel???
have you guys heard or used an electronic pad switch to activate things like nitrous purge or blanket warmer, and etc.
i want to replace the regular manual switches and connect everything into one electronic control panel. i want to do this keep the inside of the car looking clean. well what do you guys think? any help would be appreciated. thanks.
Old Mar 16, 2004 | 10:56 PM
PlastikOwl
Guest
Posts: n/a
Default Re: electronic control panel??? (SUB-0 H23)
electronic panels add problems and kill reliability..
that and you'll end up with delays...you push your purge button... the electronic panel needs to process what you programmed it for....activate some relay somewhere....etc.
keep it simple if you want reliability and no problems
Old Mar 16, 2004 | 11:08 PM
SUB-0 H23's Avatar
Default Re: electronic control panel??? (PlastikOwl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl &raquo;</TD></TR><TR><TD CLASS="quote">electronic panels add problems and kill reliability..
keep it simple if you want reliability and no problems</TD></TR></TABLE>
PlastikOwl- kool thanx for the input . im suprise that they have problems like that. hmm maybe ill look into a manual switch panel that is functunal but looks clean.
Old Mar 17, 2004 | 07:33 AM
PlastikOwl
Guest
Posts: n/a
you're only looking at maybe a second in delay....but I like **** to happen as I press the switch..not a second afterwards..and and what if something happens to the panel...you're **** out of luck with no functionality
dawrenn
May 15, 2005 01:58 PM
BB6-213
Dec 19, 2004 02:28 PM
tonezilla
Sep 11, 2004 02:50 PM
B2FiNiTY
Sep 1, 2003 05:29 PM
