Electric Wiring?
Old Jun 3, 2012 | 11:47 AM
musashiasano's Avatar
Default Electric Wiring?
Hello everyone! I have a Honda Civic EX 05.
I recently tried to replace the stereo. Everything is all wired up and installed, however, the stereo does not turn on. Additionaly, some other strange electrical issues have occurred.
  • The wireless remote to lock/unlock the doors no longer works
  • I can lock all the doors if the car is on, but if it's off, I have to manually do it (not talking about the wireless remote)
  • The alarm to warn you that the headlights are on no longer works
Any ideas what this could mean?
Thanks everyone.
Old Jun 3, 2012 | 11:58 AM
02sia2's Avatar
Default Re: Electric Wiring?
the only info we can give you is you screwed something up we didn't see what you did or how you did it so your going to have to pull your hu out and trace the wires or you chould of damaged your multiplex unit
Old Jun 3, 2012 | 07:19 PM
toyomatt84's Avatar
Sanji
The actual factory alarm and remote door locking receiving unit are both tied in to the factory head unit. So, in removing the factory head unit, you have disabled both.
Old Jun 3, 2012 | 07:28 PM
Axatax's Avatar
If you want to retain these features (and your dome light), you need to wire your new radio in such a fashion that these features are retained. You'll need to keep the OEM radio somewhere in the car, too.
Metra, maybe others, makes a very long harness to allow the OEM radio to be placed in the trunk, under the rear shelf.
http://www.installdr.com/InstallDocs...PDF/466013.pdf
Old Jun 3, 2012 | 11:06 PM
ef_newb's Avatar
it's an 05, not a 96-98
check the fuse boxes.. the fuse that provides constant power to the radio also provides power to the keyless entry module.
Old Jun 4, 2012 | 05:48 AM
fcm's Avatar
fcm
Old Fart
x2 94
Clean98EJ8
Audio / Security / Video
Feb 6, 2015 07:54 PM
Randy Castro
Jan 26, 2015 11:10 AM
Dina
Apr 9, 2012 06:32 PM
bigsyke
Mar 3, 2008 04:29 AM
