Dynamat VS offbrand
Old Mar 28, 2007 | 01:45 PM
skingfreak's Avatar
Default Dynamat extreme VS offbrand
im looking to sound deaden my trunk, doors and floor.
what are your thoughts on using dynamat extreme vs offbrand? IE: does the offbrand work as well?
Also if the offbrand stuff is good, what are some brands that are good to use? and where can you get them (internet links please )
Old Mar 28, 2007 | 02:39 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Dynamat extreme VS offbrand (skingfreak)
hush matt is good.
Old Mar 28, 2007 | 03:16 PM
skingfreak's Avatar
Default Re: Dynamat extreme VS offbrand (wrx-killer-Sti eater)
where do you get it? checked there corporate website no luck (unless im blind, just a quick glance, but seems like they want you to buy it from stores) also cant find it on ebay
Old Mar 28, 2007 | 08:46 PM
redasphalt's Avatar
edead from elemental designs http://www.edesignaudio.com
Old Mar 28, 2007 | 08:58 PM
thejacka's Avatar
http://www.sounddeadenershowdown.com
I've used both Raammat and Damplifier and both are great deadeners. Damplifiers uses a higher quality butyl that is less sticky and less messy to work with. Also it's adhesive allows you to unpeel it if you put it in the wrong spot, since it grows stronger over time. Raammat is still great and good bang for the buck. Both companies have great customer service.
Old Mar 29, 2007 | 07:48 AM
redline5th's Avatar
Default Re: Dynamat extreme VS offbrand (redasphalt)
I've heard this stuff works good.
Old Mar 29, 2007 | 08:50 AM
skingfreak's Avatar
Default Re: Dynamat extreme VS offbrand (redline5th)
thanks for the input guys, i will have to look into them, and see which one i like.
any idea on how much i will need?
if anyone else has any sugestions feel free to post em up
Old Mar 29, 2007 | 11:42 AM
thejacka's Avatar
it really depends, i have a 1998 passat, i used about 50 sq ft in the trunk/rear deck/trunk lid and about 16 sq ft. in each of my doors. covered em up pretty well, some places have double layers i couldve gotten away with less if i wanted single layer. you should look into overkill from secondskinaudio (damplifier) or ensolite from raamaudio. they work well in your doors/floor to get rid of road noise if thats part of your goal. rick provided me with some ensolite for free, enough to have a layer of each in my two front doors and the difference was actually noticeable. i'm sure overkill would have the same affect.
Old Mar 29, 2007 | 01:33 PM
skingfreak's Avatar
Default Re: (thejacka)
yeah my main reasoning for doing this is to keep the road noise down, my trunk doesnt rattle very much (running 1 12" alpine type x powered by an MA audio 1600W RMS amp)
i was planning on using dynamat extreme in the trunk/ trunk lid/ rear deck area.
i was looking on some of the different websites and they have the tar paper (dynamat extreme) and other thicker things.
which would be better for under my carpet?
Old Mar 29, 2007 | 03:03 PM
thejacka's Avatar
under your carpet i'd go with a layer of deadener and some overkill/ensolite (as they are thin, and closed cell), theyre good for airborne noise. i'd stay away from dynamat xtreme unless you can get it for the same price as raammat or damplifier. its not tar, all 3 are butyl.
Old Mar 29, 2007 | 05:17 PM
redasphalt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak &raquo;</TD></TR><TR><TD CLASS="quote">yeah my main reasoning for doing this is to keep the road noise down, my trunk doesnt rattle very much (running 1 12" alpine type x powered by an MA audio 1600W RMS amp)
which would be better for under my carpet?</TD></TR></TABLE>
road noise is a different frequency then what rattling is... using dynamat and the like are just adding weight to panels to keep them from vibrating and creating rattles... i would seriously look into edead teklite from elemental designs... its a foam layer that helps cancel out road noise... i noticed the best place to put deadener to kill road noise in my car was along the fender walls
Old Mar 29, 2007 | 06:06 PM
vtecrehab's Avatar
Default Re: (redasphalt)
What does everyone think of those door kits sold in stores?
Old Mar 29, 2007 | 06:25 PM
skingfreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redasphalt &raquo;</TD></TR><TR><TD CLASS="quote">rattles... i would seriously look into edead teklite from elemental designs... its a foam layer that helps cancel out road noise</TD></TR></TABLE>
How thick is it? do you know of somewhere to get it cheap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redasphalt &raquo;</TD></TR><TR><TD CLASS="quote">i noticed the best place to put deadener to kill road noise in my car was along the fender walls </TD></TR></TABLE>
Did you use something along the lines of dynamat on the fenderwells? did you do the front this way in the engine bay as well?
Old Mar 29, 2007 | 06:37 PM
redasphalt's Avatar
Default Re: (skingfreak)
Did you use something along the lines of dynamat on the fenderwells? did you do the front this way in the engine bay as well?</TD></TR></TABLE>
check out this link for more info: http://www.edesignaudio.com/ed...id=55
Old Mar 29, 2007 | 06:39 PM
skingfreak's Avatar
thanks for the link.
would you run into any issues with carpet fitment after installing?
Old Mar 29, 2007 | 06:53 PM
redasphalt's Avatar
i have a del sol so not much carpet, but u will have to cut out holes for everything... i dont think it would be too bad
Old Mar 29, 2007 | 07:08 PM
thejacka's Avatar
i'd still stick to second skin's overkill or ensolite. http://www.raamaudio.com http://www.secondskinaudio.com
thejacka's Avatar
Default Re: (vtecrehab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecrehab &raquo;</TD></TR><TR><TD CLASS="quote">What does everyone think of those door kits sold in stores?</TD></TR></TABLE>
if you're referring to dynamat xtreme, don't get it. its a ripoff for so little deadener.
Old Mar 29, 2007 | 08:22 PM
mr poo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redasphalt &raquo;</TD></TR><TR><TD CLASS="quote">edead from elemental designs http://www.edesignaudio.com</TD></TR></TABLE>
and ever since the sounddeadenershowdown.com they've upgraded theirs to butyl rubber. best mat value out there imo
Old Mar 29, 2007 | 08:24 PM
redasphalt's Avatar
Default Re: Dynamat extreme VS offbrand (mr poo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr poo &raquo;</TD></TR><TR><TD CLASS="quote">
and ever since the sounddeadenershowdown.com they've upgraded theirs to butyl rubber. best mat value out there imo </TD></TR></TABLE>
too bad they dont have the forum discount anymore
Old Mar 30, 2007 | 01:33 PM
skingfreak's Avatar
do any of these compantys have a forum discount?
Old Mar 30, 2007 | 02:13 PM
mr poo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redasphalt &raquo;</TD></TR><TR><TD CLASS="quote">too bad they dont have the forum discount anymore </TD></TR></TABLE>
http://www.edesignaudio.com/ed...th=90
shipping is what ends up biting you with all these mat products. but another plus to elemental designs, their customer service is great and they'll take care of you if you order over the phone.
Old Mar 30, 2007 | 06:33 PM
imadigitalgod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thejacka &raquo;</TD></TR><TR><TD CLASS="quote">
if you're referring to dynamat xtreme, don't get it. its a ripoff for so little deadener.</TD></TR></TABLE>
regardless of the price, is xtreme really good compared to the others? i know its way expensive in the stores tho
Old Mar 30, 2007 | 06:56 PM
nineohtoo's Avatar
Default Re: (imadigitalgod)
^ From what I've read here and heard at the ccity roadshop I work at, certain brands may need more layers to dampen as much sound. In the end, even multiple layers of the other stuff is usually cheaper unless you can get a good discount on it, or see deals on ebay.
Old Mar 30, 2007 | 07:15 PM
Default Re: (nineohtoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nineohtoo &raquo;</TD></TR><TR><TD CLASS="quote">^ From what I've read here and heard at the ccity roadshop I work at, certain brands may need more layers to dampen as much sound. In the end, even multiple layers of the other stuff is usually cheaper unless you can get a good discount on it, or see deals on ebay. </TD></TR></TABLE>
im saying if price wasnt a factor, if all brands were the exact same price, would Dynamat Extreme come out on top?
