Door speaker clearance
Old Feb 9, 2003 | 03:27 PM
vteg's Avatar
New User
Default Door speaker clearance
Can I use a 3/4 wood spacer ontop of the plastic spacer in a g3 teg and still get the panel back on? The damn terminals on the kickers are hitting the edge of the door and preventing me from installing it. I got 1.5 inch screws, now I need another half inch just to test If it will not make it I guess I will have to pick up some snips.
Old Feb 10, 2003 | 12:05 AM
vteg's Avatar
New User
Default Re: Door speaker clearance (vteg)
bump
I have a dremel and I am not afraid to use it
Old Feb 10, 2003 | 04:46 AM
t0p_sh0tta's Avatar
I did that with my DEI's on my civic, but the speakers hit the door panel when the volume is up. I have a layer of RAAMmat and rubber undercoating on the panel though (maybe 1/4") You might be able to mod the door panel alittle. Good luck.
Edit: Could you use maybe 1/4" or 1/2"?
[Modified by t0p_sh0tta, 8:47 AM 2/10/2003]
Old Feb 10, 2003 | 03:51 PM
vteg's Avatar
New User
Default Re: Door speaker clearance (t0p_sh0tta)
Did you use just a 3/4 inch wood spacer or did you put another spacer on top of the factory one. Tonight I will measure the terminals. I think a 1/4 or 1/2 spacer will work. Back to home depot. The stock spacer is 3/4.
Old Feb 11, 2003 | 02:10 PM
t0p_sh0tta's Avatar
I used 3/4" on top of the factory thing, because I had bad seals and I didn't want the speakers getting soaked.
Old Feb 11, 2003 | 06:04 PM
vteg's Avatar
New User
Thanks alot! That is exactly what I was looking for
I measured the terminals last night, they are 1 3/8 inch off the mounting surface. I would do it tonight but it is raining.
Old Feb 22, 2003 | 03:29 PM
vteg's Avatar
New User
For completeness. A 3/4 inch spacer on top of the stock spacer will not make it under the door panel of a g3 teg.
Old Feb 22, 2003 | 04:26 PM
MachAF's Avatar
I had to get 1inch spacers for my CDT components to fit. Sucks that they didn't make the door deeper. Doesn't look very clean, but what can you do? Gotta get some thin speakers.
You can buy spacers at bestbuy and prolly other audio shops.
Old Feb 22, 2003 | 05:12 PM
vteg's Avatar
New User
Default Re: Door speaker clearance (machaf)
Thanks for the suggestions. They are in the door. I had to snip about 1/4 of an inch of metal at the sides to let the terminals clear the hole. I used a 3/4 inch spacer.
Jaydeep
Apr 23, 2011 10:16 AM
Rizz
Feb 7, 2007 02:53 AM
96integraGSR
Apr 11, 2006 08:34 PM
Rob!
May 31, 2002 06:16 AM
