Door poppers
its not hard... i have them in my truck. the door poppers have two wires, one is a ground the other is a power, the one that makes it pull is going to be the one that you use as a power, then you run the power to a constant +12v and the ground you run to a relay and from the relay to the alarms unlock wire, for my passenger side i used the trunk/channel 2 wire.
SuicideSlide
Sep 3, 2003 03:14 PM
