Door Panel Tweeters
Old Mar 9, 2002 | 10:13 AM
92cxgsr's Avatar
Default Door Panel Tweeters
Has anyone installed door pannel tweeters? Like the ones that came in some of the 92-95 civics?? Has anyone drilled holes for them ever since their car didn't come with holes already fabricated? Let me know, Also how do I wire them up if they weren't already in my car. I have a 92 cx
Old Mar 9, 2002 | 11:32 AM
92cxgsr's Avatar
Default Re: Door Panel Tweeters (92cxgsr)
TTT anyone
Old Mar 9, 2002 | 11:52 PM
redblues's Avatar
New User
You need a hole saw the diameter of the tweeter mounts. To mark the center of the hole properly on both panels make a template on paper, mark the center on the door panel then turn the paper over and mark on the other panel.
You can run wires to the door through the existing wire loom if you can squeeze it in, otherwise drill another hole under the existing loom and run the wires through that.
If you're lazy just surface mount them to your A-pillars.
Old Mar 11, 2002 | 07:31 AM
92cxgsr's Avatar
ok thanks
dweston
12
Mar 19, 2013 03:27 AM
pez1
Apr 11, 2006 09:22 AM
93gsrhatchbrid
Audio / Security / Video
Apr 2, 2006 01:52 PM
BrainzIRL
Feb 23, 2006 01:20 PM
kysard
Mar 7, 2004 01:26 PM
