Do you need to charge your cap?
Old Oct 20, 2004 | 07:09 AM
SubsonicSPL's Avatar
Default Do you need to charge your cap?
Some say yes, some say no, i have the resistor, is there a need to charge it?
DAXX c10 1 farad cap
Old Oct 20, 2004 | 07:52 AM
rcurley55's Avatar
New User
Default Re: Do you need to charge your cap? (SubsonicSPL)
yes
Old Oct 20, 2004 | 09:10 AM
nsxxtreme's Avatar
If you don't mind sparks when you connect it no. The resistor just slowly charges the cap. The resistor is a current limiter.
Old Oct 20, 2004 | 09:12 AM
rcurley55's Avatar
New User
Default Re: Do you need to charge your cap? (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">If you don't mind sparks when you connect it no. The resistor just slowly charges the cap. The resistor is a current limiter.</TD></TR></TABLE>
point taken, but a 10F cap....that's going to be one hell of a spark....
btw, don't hold the resistor in your hand - it would be far smarter to use a lightbulb. When the bulb turns off, the cap is charged.
Old Oct 20, 2004 | 10:36 AM
PM-Performance's Avatar
are you referring to charging or discharging the cap? As far as i was aware you use the resistor to discharge the stored energy in the cap before installing it so you dont take the risk of spraking like hell and possibly damaging it. This goes true with some amps also. Mosty Hi current ones. As far as charging it, when you hook it up and let the car run, that should be how you correctly charge the cap.
Correct me if im wrong here, but this is simple electronics.
Old Oct 20, 2004 | 11:25 AM
rcurley55's Avatar
New User
Default Re: Do you need to charge your cap? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">are you referring to charging or discharging the cap? As far as i was aware you use the resistor to discharge the stored energy in the cap before installing it so you dont take the risk of spraking like hell and possibly damaging it. This goes true with some amps also. Mosty Hi current ones. As far as charging it, when you hook it up and let the car run, that should be how you correctly charge the cap.
Correct me if im wrong here, but this is simple electronics. </TD></TR></TABLE>
You are wrong Well, not wrong, just backward.
You charge the cap before you install, discharge it after. Like it was mentioned above, if you don't, you will have some nice sparks when you attempt to connect the cap b/c it's going to suck up current.
Some amps that had large cap banks built in - the soundstream reference 1000's come to mind - advised people to charge the amp first before attaching the power wire.
The resistor/bulb/whatever, is just there to slow the current flow into the item being charged. This is why I use a 12V test light. Hook up the ground to the cap. Then hook one side of the test light to the positive side of the cap, the other end to the positive wire. hold it there until the light is COMPLETELY out. Then attach the power wire and you are good to go. To discharge, just connect the lamp across the terminals of the cap - when the light is out, cap is discharged.
Old Oct 20, 2004 | 12:28 PM
Default Re: Do you need to charge your cap? (rcurley55)
ok, i get what you are saying. i was backwards in my thinking i know with my soundstream stuff i had to charge them 1st. i thought it was discharging them though. lol
lilblrex
Feb 13, 2008 06:10 PM
DFW
Feb 14, 2007 11:24 PM
B18EG6
Audio / Security / Video
12
Jul 7, 2005 05:20 PM
vtec-outlaw
Jan 28, 2002 03:28 PM
