do i NEED a RELaY
Old May 8, 2005 | 03:10 PM
BLUE EH3's Avatar
Help we my pennies
Default do i NEED a RELaY
what is a relay for?? i just got a aftermarket horn, it works fine, but the kit came with a relay and i DIDNT use it
Old May 9, 2005 | 09:12 AM
VTECorona's Avatar
Default Re: do i NEED a RELaY (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">what is a relay for?? i just got a aftermarket horn, it works fine, but the kit came with a relay and i DIDNT use it</TD></TR></TABLE>
It probably requires more power than the stock horn so a relay allows the new horn to get current directly from the battery instead of from the OEM horn wiring, which is probably super thin. The wiring harness with the aftermarket horn will probably use the OEM horn wire as a trigger and have another wire that goes directly to the battery. Thats how the plug-n-play HID wiring harnesses work atleast. If your horn stops working for some reason then you may have blown a fuse, which is another reason why the wiring harness is probably a better route.
PM me if you need any help
Old May 9, 2005 | 09:35 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">what is a relay for?? i just got a aftermarket horn, it works fine, but the kit came with a relay and i DIDNT use it</TD></TR></TABLE> If you you plugged it into the stock horn output wire, you don't need it. A relay lets you use a low current switch, [ 150-250 mA] to trigger the relay, [a relay is a switch] and the relay supplies the high current, [25 - 30A] the input to the relay would be wired to the batt. the output to the horn and the trigger can be wired, [pos. (+) or neg. (-)] the stock horn button is neg. (-) but the output to horn is pos. (+) 94
Old May 9, 2005 | 02:55 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: do i NEED a RELaY (fcm)
thank you guys!
NovaRex
Apr 20, 2015 02:14 PM
pnwjdm
17
Sep 29, 2013 01:11 PM
tei344
Nov 9, 2007 05:51 AM
Azxster
Audio / Security / Video
Feb 23, 2006 11:14 AM
spooncivic1
May 17, 2005 08:12 AM
