Do I need a capacitor or alternator?
Old Oct 9, 2005 | 11:07 AM
mulletov's Avatar
Default Do I need a capacitor or alternator?
I'm running 2 amps. a JL e4300 x4 ch and a JL 300/2 x1 to an 12" alpine type e. When I first turn on the system, it sounds loud and theres lots of bass. After awhile of playin like 30-60 min at high volume, the bass hits less and less. Sometimes one of my amps will turn off and then turn back on after a couple minutes. At night I have NO dimming lights or anything. the e4300 makes 45wx4 rms and the 300/2 makes 300wx1 rms. I was thinking about upgrading to a 500/1 and a 300/4 to see if I would still have this problem. All this in a 99 civic coupe. What would cause the decrease in bass and how to solve this?
Old Oct 9, 2005 | 12:33 PM
fcm's Avatar
fcm
Old Fart
Default Re: Do I need a capacitor or alternator? (mulletov)
If you are not having dimming problems, and you are not running into low batt., [starting] problems, [after running the system for 30 -60 min.] the first thing I would check is power and ground connections and with your symptom's I would check the main power fuse and/or any fuses at a splitter, for heat after running the system to the point that the bass stops "hitting as hard", be careful if the problem is the fuse it can be very hot. 94
ejfromwestbay
38
Nov 29, 2011 07:13 PM
mnizzy
Audio / Security / Video
Sep 12, 2006 05:08 PM
Chilly61383
May 23, 2005 09:09 PM
agent marlon
Mar 30, 2003 06:29 PM
AlphaKennyWun
10
Mar 1, 2002 11:50 PM
