DIN Gauge Install
Old Oct 19, 2007 | 07:41 AM
flyingduck04's Avatar
Default DIN Gauge Install
I have a 00 Em1 I am trying to put a set of gauges into the audio console and I was just curious if a DIN Sized block off plate would fit the gauges, I have searched for pics but have not found anything. Thanks in advance
Old Oct 19, 2007 | 07:49 AM
B18C_EJ8's Avatar
I don't really get your question? Are you asking if the factory radio in an EM1 is din-sized?
Old Oct 19, 2007 | 07:56 AM
Default Re: (B18C_EJ8)
Not necessarily, I am trying to figure out with an aftermarket stereo in will there be enough room to put the DIN block plat in as well ast he gauges. Here is a pic of what I am talking about. I want to put the gauges in that pocket area under the radio, but i am just not sure if it will fit.
Old Oct 19, 2007 | 08:00 AM
B18C_EJ8's Avatar
Yes. The opening in the dash is a double DIN. 2 1/16" gauges will fit nicely.
Old Oct 19, 2007 | 08:09 AM
Awesome, thanks man. I am going to order my holder today and see how it turns out.
Old Oct 19, 2007 | 08:10 AM
B18C_EJ8's Avatar
Are you running the stock deck or an aftermarket unit?
Old Oct 19, 2007 | 08:21 AM
aftermarket(Pioneer)
Old Oct 19, 2007 | 08:45 AM
B18C_EJ8's Avatar
If you're using a dash kit, depending on the gauge panel you choose, you may need to ISO mount the Pioneer and ISO mount the gauges...
Let us know which panel you're getting and we'll figure out how to mount it the best & most secure way.
Old Oct 19, 2007 | 09:32 AM
Some of the ones that I have been looking at are angled, and some are flat but here are the two that i am looking at.
Old Oct 19, 2007 | 10:48 AM
B18C_EJ8's Avatar
Go with the top one... Looks like it'll give you the brackets needed to install it quite securely in an ISO mount fashion.
Old Oct 19, 2007 | 06:11 PM
CarbonizedDX's Avatar
I got the triple angled unit off ebay:
I like that the holder is angled BUT the metal is thin, the mounts had to be removed and to keep the holder in place it's JB welded in.... Overall I'm happy but it's a bit permanent so I'd say with the units you've pictured to go with the first one, it looks better designed...
flyingduck04
Oct 23, 2007 07:53 AM
flyingduck04
Oct 19, 2007 08:11 AM
RacerBoy
Nov 10, 2002 08:52 PM
02WRX
Jul 29, 2002 01:47 PM
00PurpleGSR
Jun 20, 2002 12:39 AM
