Difference between cheap and expensive sub enclosure?
Old Dec 7, 2010 | 06:00 AM
  #26
fcm's Avatar
fcm
Old Fart
Default Re: Difference between cheap and expensive sub enclosure?
Because the amp is for a sub you will set the "Frequency" to low-pass, punch bass off, the phase switch can be switched just about anytime and leave it where the sub sounds the best, there is no wrong position, the correct position is when the sub sounds the best to you.
Turn the bass remote volume control all the way up when adjusting the amp gain.
Yes, bass and treble flat on the stock HU. 94
Old Dec 7, 2010 | 09:51 AM
  #27
butterbeer2fd's Avatar
Ahh okay gotcha, what number hz would you I suggest I set it at? The range goes from 40hz to 130 hz.
Old Dec 7, 2010 | 10:38 AM
  #28
edzy's Avatar
80
Old Dec 7, 2010 | 10:51 AM
  #29
fcm's Avatar
fcm
Old Fart
I agree, start at 80Hz, but try it all the way up to 100Hz and maybe as low as 70Hz, the low-pass x-over point, [low-pass or upper cut] will depend on a number of things, mostly how the bass sounds to you when playing the music you like. 94
Old Dec 7, 2010 | 02:01 PM
  #30
Got it, thanks everyone! Out of all the threads I posted on other forums, this one helped the most...guess Honda Tech isn't full of haters after all
Old Dec 7, 2010 | 03:07 PM
  #31
nsxxtreme's Avatar
Originally Posted by fcm
The box needs to be the correct size, [internal volume] for the sub for best results, and the correct "shape", EG; a 1cuft box should not be 12"x12"x12", a cube, it should have as many non parallel sides as possible and diff. HxWxD.. 94
Any reference material regarding this? News to me, even high end home audio subwoofers generally use a cube.
Old Dec 7, 2010 | 07:46 PM
  #32
fcm's Avatar
fcm
Old Fart
Look inside a high end home sub cabinet.
Although there is a debate about standing wave propagation in a box with parallel surfaces, with a cube box being the worst, and it's effects on SPL/SQ...
http://www.ajdesigner.com/speaker/bcv.php 94
I have built cubes for sub boxes, there are ways to deal with standing waves, one of the best ways is not to build a cube, [or in OPs case, buy one] if you do not have to.
Even if, as some say, it does not make enough of a difference to make it worth the effort, IMO anything that can be done that will make a difference should be done.
For sub bass, either for SPL or SQ, [or both] it's all about the cabinet, yes the quality of the speaker makes a difference also, but I don't care how much you spend on the sub, if the box is wrong the bass will suck. 94
Old Dec 10, 2010 | 08:48 AM
  #33
nsxxtreme's Avatar
I have mine....it's a cube
http://www.sunfire.com/productdetail.asp?id=8
Old Dec 10, 2010 | 11:07 AM
  #34
fcm's Avatar
fcm
Old Fart
The outside dimensions are the same, [13.5" cube], pull the driver or amp and look inside the box, pretty good bet it is no longer a cube, the fact that the amp/x-over is mounted to one side of the box makes at least one dimension different, you will most likely also find bracing and dampening material inside the cabinet. 94
Old Dec 10, 2010 | 03:12 PM
  #35
nsxxtreme's Avatar
I'm just giving you a hard time, as I have heard similiar statements before but have never seen any good reference material with some science behind the statements. A lot of high end woofer enclosures are cubes.
davidluko
Audio / Security / Video
Feb 14, 2006 07:04 PM
brickonwheels
Jan 6, 2006 01:32 PM
QQBeNNyQQ
Feb 11, 2005 01:57 PM
esoterEK..
Dec 17, 2004 04:27 PM
GroundZer0 336
24
Apr 13, 2003 06:18 PM
