Depth of door mounts in Integra
Old Apr 18, 2005 | 07:17 AM
Miz101's Avatar
Default Depth of door mounts in Integra
Hi my cousin is trying to mount a set of Oz speakers but it seems they might be a bit to big. He's using a 1 Inch baffle and they are still to big. Does anyone know what is the max you can fit in an Integra door?
Thanks!
Old Apr 18, 2005 | 08:13 AM
B18C_EJ8's Avatar
Default Re: Depth of door mounts in Integra (Miz101)
Did he cut out the plastic basket first? You can cut that out, and fit most speakers in there afterward...
Old Apr 18, 2005 | 12:27 PM
Miz101's Avatar
Default Re: Depth of door mounts in Integra (B18C_EJ8)
I will ask him later today. I don't think he has done anything to the doors so I'm pretty sure he hasn't.
Old Apr 18, 2005 | 02:16 PM
Miz101's Avatar
Ok I asked him and he removed the basket completely. They still don't fit. He told me they are 3" inches deep and a bit over 6.5 inch wide.
Old Apr 18, 2005 | 03:52 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miz101 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I asked him and he removed the basket completely. They still don't fit. He told me they are 3" inches deep and a bit over 6.5 inch wide.</TD></TR></TABLE>LOL........... 3" deep they may not even fit with depth reducers,[spacer] cut out the back of the OEM speaker basket, measure from the window or window guide to the outside edge of the speaker basket, if you get 2" or more, you can add up to a 1" MDF spacer without to much of a problem, any thicker and you will have problems getting the door panel back on. 94
Old Apr 18, 2005 | 08:14 PM
Miz101's Avatar
Default Re: Depth of door mounts in Integra (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">LOL........... 3" deep they may not even fit with depth reducers,[spacer] cut out the back of the OEM speaker basket, measure from the window or window guide to the outside edge of the speaker basket, if you get 2" or more, you can add up to a 1" MDF spacer without to much of a problem, any thicker and you will have problems getting the door panel back on. 94</TD></TR></TABLE>
Yep that is the problem. He us using a 1 inch baffle but like you said the only way he would be able to get the door panel back on is if he modified it. Oh well there goes a perfectly good set of Oz speakers.
I hope my DLS Iridiums fit when I get them... I should check the specs on them again.
Old Apr 19, 2005 | 06:10 AM
fcm's Avatar
fcm
Old Fart
I hope my DLS Iridiums fit when I get them... I should check the specs on them again.</TD></TR></TABLE>Install them in the rear locations, [the OZ ones] and put something else up front 94
enphotography
Mar 15, 2006 03:37 AM
sinister357
Audio / Security / Video
Feb 2, 2006 06:09 PM
kingrd
Jul 9, 2005 07:37 PM
Loveless
Feb 20, 2003 09:38 AM
Veritas-Aequitas
Feb 5, 2003 09:13 AM
