Deck cutting in and out?
Old Jan 24, 2006 | 10:46 PM
NuGgEt's Avatar
Default Deck cutting in and out?
This started happening a couple week ago. Ive had a sony xplode deck for who knows how long and its always been good to me, but lately every 10 minutes or so it just randomly turns off for 5-10 seconds then comes back one. All the settings are saved and just fine... it just cuts out for a second. Once it lost all the memory and settings and reset, but only once. Any ideas?
Old Jan 25, 2006 | 03:12 AM
john666's Avatar
Default Re: Deck cutting in and out? (NuGgEt)
probably a loose wiring in the back of the HU. or if u have amps a loose wire there.
Old Jan 25, 2006 | 01:43 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NuGgEt &raquo;</TD></TR><TR><TD CLASS="quote">This started happening a couple week ago. Ive had a sony xplode deck for who knows how long and its always been good to me, but lately every 10 minutes or so it just randomly turns off for 5-10 seconds then comes back one. All the settings are saved and just fine... it just cuts out for a second. Once it lost all the memory and settings and reset, but only once. Any ideas?</TD></TR></TABLE>
any money it was installed with electircal tape. am i correct? sounds like loose wiring.
Old Jan 25, 2006 | 02:30 PM
NuGgEt's Avatar
Default Re: Deck cutting in and out? (EBP_SI)
Thats what I thought too but everythin is connected just fine. And no, not electical tape haha.
Old Jan 25, 2006 | 03:50 PM
fcm's Avatar
fcm
Old Fart
A little more info, you say it "cuts out" do you mean the sound cuts out, [and the "lights" stay on] or the power cuts out, [like when you turn off the ign.]? 94
Old Jan 26, 2006 | 12:39 AM
NuGgEt's Avatar
Default Re: Deck cutting in and out? (fcm)
It turns off, like when I turn off the ignition. Only it only turns off, not loses all power cause it doesnt lose all the settings.
Old Jan 26, 2006 | 05:24 PM
fcm's Avatar
fcm
Old Fart
Then You are loosing power to the red acc. wire on the HU, [yellow/red in the cars radio harness], replace the oem radio fuse in the under dash fuse box, [just in case it's defective] also make sure the fuse "legs" are making good contact in the fuse socket, [wiggle the fuse in it's socket with the HU turned on se if it cuts out]
Also check the fuse on the HUs red acc. wire, [if it has one]
And remember just because the fuse looks ok, does not mean it is, the vibration in a car can break the filament, and the fuse would be intermittent. 94
Quick99Si
Audio / Security / Video
Mar 20, 2007 03:54 AM
8894honda
Jun 16, 2006 04:24 PM
T-RO
Apr 23, 2005 07:36 AM
initialvtec
Mar 14, 2005 03:16 PM
96Civic_Coupe
Jul 2, 2004 03:36 PM
