cutting plexiglass
Old Feb 8, 2005 | 03:40 PM
jb.'s Avatar
jb.
Default cutting plexiglass
i have an extra piece of plexiglass from an old bandpass box and i want to mount my amp just to the piece of glass. i am wanting to know if there is any special blade or saw that i need to cut it into different size pieces.
Old Feb 8, 2005 | 03:52 PM
Auex's Avatar
Default Re: cutting plexiglass (jbkiksass69)
Fine tooth blade or router.
Old Feb 8, 2005 | 04:40 PM
jb.'s Avatar
jb.
Default Re: cutting plexiglass (Auex)
would a jig saw have enough power to cut it
Old Feb 8, 2005 | 05:09 PM
Auex's Avatar
A jig saw will more then likely chip the plexi regardless of how fine the blade is.
Old Feb 8, 2005 | 07:55 PM
Bbasso's Avatar
Not true if you have the right blade...
If you use a jigsaw be sure to find the right speed, too fast will cause it to melt and to slow will cause it to vibrate and possibly break.
How thick is the plexi you want to cut?
Old Feb 9, 2005 | 06:33 AM
n0 iNTegRiTY's Avatar
I would recommend scissors or pruning shears.
Old Feb 9, 2005 | 06:34 AM
Default Re: cutting plexiglass (n0 iNTegRiTY)
(That was a joke... don't actually do that)
Old Feb 9, 2005 | 06:37 AM
jb.'s Avatar
jb.
lol...its about 1/2 thick
Old Feb 9, 2005 | 06:52 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbkiksass69 &raquo;</TD></TR><TR><TD CLASS="quote">i have an extra piece of plexiglass from an old bandpass box and i want to mount my amp just to the piece of glass. i am wanting to know if there is any special blade or saw that i need to cut it into different size pieces.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auex &raquo;</TD></TR><TR><TD CLASS="quote">Fine tooth blade or router.</TD></TR></TABLE>Ditto the router, best way, you can also cut it on a table or radialarm saw as long as it a finishing blade, with carbide teeth 94
Old Feb 9, 2005 | 09:04 AM
jb.'s Avatar
jb.
Default Re: cutting plexiglass (fcm)
just to make sure, the plexiglass will be ok to mount a jl 500/1 amp and it wont be too hot or anything like that
Modified by jbkiksass69 at 11:25 PM 2/10/2005
Old Feb 10, 2005 | 07:25 PM
jb.'s Avatar
jb.
anyone know the last question
Old Feb 11, 2005 | 05:21 AM
Bbasso's Avatar
rememeber that it's only plastic and will defrom from heat like any other non abs plastic. I used 1/4 inch plexi in my turtle tank and it gets about 85deg in there and slowly bends then 1/4 inch. be sure to have plenty of air between the amp and plexi to keep it cool.
Old Feb 11, 2005 | 08:20 AM
jb.'s Avatar
jb.
Default Re: cutting plexiglass (Bbasso)
thanks
Old Feb 11, 2005 | 10:43 AM
Vero's Avatar
if you scour it on both sides with a utility knife (a good one). It should just break at the lines.
You may need to scour with some pressure, or do it a few times. Depedning on the thicnkness.
Skapeoner
Nov 14, 2006 10:56 AM
nuttybumpo
Audio / Security / Video
Jul 13, 2006 12:03 PM
Immanuel
Dec 26, 2005 12:11 PM
RCautoworks
Welding / Fabrication
Jul 12, 2005 01:13 PM
david
Jun 9, 2005 10:27 AM
