converting manual window to power??
Old Aug 1, 2004 | 11:45 AM
staticimports's Avatar
Default converting manual window to power??
if i have a 92 hatch with manual windows and i want to convert to power windows, will i have to change the whole door panel to allow for the power window button or what will i need to do?? does anyone also know the approx. cost of this project
Old Aug 1, 2004 | 02:01 PM
john666's Avatar
Default Re: converting manual window to power?? (staticimports)
Try a search beofre posting,... It will probably be cheaper for you to buy EX doors and either use those doors or swap internals over, then just wire them up, Im not sure how much the doors will cost in your area but around here bout 200 for perfect doors with panels .
Old Aug 1, 2004 | 03:36 PM
Eric R's Avatar
Depending on the area, you're looking to spend about $165 to $199 per door to install power windows with switches and everything.
Spal makes one of the best parts in the market. Some kits migh come with mounting pods to install the switches. The good thing about their switches is they have illumination so you can hook them up to your parking or dash lights for night use.
When I install them, in some cases, I can use these pods to cover the whole where the crank used to be. This way I don't have to use the ugly plastic caps they provide.
This isntallation is very straight forward and don't need relays. Just a lil patience and a good time.
Eric
Old Aug 1, 2004 | 05:32 PM
Default Re: converting manual window to power?? (Eric's R)
thanks guys i will get on it
Old Aug 2, 2004 | 10:06 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eric’s R &raquo;</TD></TR><TR><TD CLASS="quote">Depending on the area, you're looking to spend about $165 to $199 per door to install power windows with switches and everything.
Eric</TD></TR></TABLE> http://www.spal.com. 94
Germizzooo
Nov 20, 2011 08:10 AM
boostedefhatch
Feb 19, 2010 07:57 PM
k20GSR
Feb 8, 2005 08:20 PM
90da4dr
Dec 20, 2004 10:31 AM
SingleCamIam
16
Sep 17, 2003 10:05 AM
