Constant 12V
Old Jul 12, 2005 | 11:50 PM
skrewdriver88's Avatar
Default Constant 12V
I know that the top 5 slots on the fuse box are 12V sources but which ones are constant and which ones are triggered(like only have power when the key is in ACC.)?
TIA
Old Jul 13, 2005 | 06:24 AM
pnthr30's Avatar
Default Re: Constant 12V (skrewdriver88)
It is easy enough to check, but if I remember correctly, the first one (on the left side) is a constant (in my 99 Integra GS)..........I don't remember how the others function - sorry. Good luck.
Old Jul 13, 2005 | 06:56 AM
fcm's Avatar
fcm
Old Fart
That seems to change from model to model and year to year, you need to test them to be sure, but you will find 12V+ constant, acc. 2nd ign. park light, and some times I find on that seams to do nothing at all 94
Old Jul 13, 2005 | 12:11 PM
The Weather Man's Avatar
How do you hook wires to the fuse panel?
Old Jul 13, 2005 | 01:22 PM
pnthr30's Avatar
Default Re: (NaptownKing)
Above the fuse panel, there are a couple of male spade termals that can be easily accessed.
Old Jul 13, 2005 | 01:24 PM
fcm's Avatar
fcm
Old Fart
Flat female 250 Quick disconnects, the same one you use on most speaker pos. (+) term. or both pos. (+) and neg. (-) on most subs. 94
BTW the term. on the fuse box are called "freepins"
Old Jul 14, 2005 | 03:48 PM
PupaScoopa's Avatar
Default Re: (fcm)
Why take a chance? Just use a voltmeter to check which is constant and which is switched.
ScottieA
Jan 18, 2006 09:36 PM
19codyscivic94
Audio / Security / Video
Dec 19, 2005 04:57 PM
phoshizzle88
Sep 15, 2005 09:47 AM
GumballNA
Nov 16, 2004 02:35 PM
cohasi2003
Mar 2, 2003 03:30 PM
