Compustar Pro Tach Sensing Error
Old Apr 4, 2011 | 04:41 AM
h22a_black's Avatar
Default Compustar Pro Tach Sensing Error
Hey everyone, having a bit of an issue with the auto start on my compustar pro.
Car is a 97 Accord Ex-R. I have connected the tach sensing wire to the blue wire on the coil. When I do the tach learning, the brain accepts the signal and everything is fine, but when I go to actually start the car, I get error 8, tach/voltage sensing failure, any ideas as to what this could be?
TIA
Old Apr 4, 2011 | 01:52 PM
h22a_black's Avatar
Default Re: Compustar Pro Tach Sensing Error
Just went out and tried on a non common injector wire... same results
Old Apr 6, 2011 | 06:19 AM
fcm's Avatar
fcm
Old Fart
Where did you get the Compustar Pro from, was it an authorized Compustar dealer? 94
Old Apr 6, 2011 | 07:13 AM
h22a_black's Avatar
Unfortunately no, it was bought off someone other than an authorized dealer, however it was a new warranty replacement.
I traced down the issue to the clutch switch. I connected status out to the red/blue wire coming off the switch but Im assuming that was the incorrect wire somehow. For now I jumped the switch and everything is working perfect, but I plan to revisit when its a little warmer.
esean93
Aug 23, 2008 10:33 AM
slimjimdanny
Jan 31, 2007 07:35 PM
90crxdriver
10
Nov 4, 2006 12:14 PM
BROKE.eg
Nov 20, 2005 02:03 PM
Jeef
May 5, 2004 07:18 AM
