Compustar has a mind of its own...
Old Apr 3, 2005 | 10:43 AM
pdiggitydogg's Avatar
Default Compustar has a mind of its own...
I am getting a bit frustrated with my compustar 2wss.
No matter what I do with passive arming the alarm will activate itself after closing the doors. Think of how bad this sucks when Im under the hood for general maint and the damn siren goes off in my ear.
Ive tried turing it off and turing it on (thinking it may be backwards for some reason). The indicator on the lcd does indicate that it is either on/off....but the brain continues to stay on passively armed.
I DONT WANT IT ON ALL THE TIME!
So far Im leaving it in valet mode almost constantly and its really starting to bug me.
Any suggestions other than "call your dealer" and "try pressing buttons II+III together" will be greatly appreciated.
I mean, its not supposed to do this, right?
Old Apr 4, 2005 | 12:02 PM
no one?
Old Apr 4, 2005 | 04:41 PM
EGPrelude's Avatar
uhh...just to get it straight, i believe passive arming is when the alarm arms itself in a certain amount of time
active arming is when you have to "actively" arm it yourself by pushing a button
Old Apr 4, 2005 | 04:42 PM
EGPrelude's Avatar
i didnt mean to say it with any negative conotation, im just clearing it up because some people get it confused
so you've tried setting it to active arming?
Old Apr 4, 2005 | 07:22 PM
thats correct
the active arming is when passive is turned off; automaticly changes. There is no active/manual arming mode.
Its just stuck in passive, even when I tell it not to be and remote says its not.............pisses me off
Old Apr 5, 2005 | 07:07 AM
Come on...Im getting zero help from compustar tech
Old Apr 5, 2005 | 07:59 AM
vigor5spd's Avatar
Default Re: (pdiggitydogg)
If the remote display says the Passive arming is off then that feature is not on.
One reason you think its still on is because when u disarm and do not open the door the alarm will rearm itself just incase the button was pressed on accident.
If you disarm and open a door then the alarm will not arm itself unless you do it.
This function is called active alarming.
Old Apr 5, 2005 | 08:03 AM
nope...even if I open the door it still passively arms.
Factory keyless does that too, so that was one of the first things I tried.
Old Apr 5, 2005 | 09:18 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">nope...even if I open the door it still passively arms.
Factory keyless does that too, so that was one of the first things I tried.</TD></TR></TABLE> The brain may be "latched up" just like a computer, if this is the case, you will have to reboot it, disconnect the neg. batt. term. or the Compustars main power plug, let sit for 5 or 10 min., reconnect and reprogram, test, if problem is still there, return it to where you got it, Compustar has a liftime warranty, if you got it at an auth. dealer. 94
Old Apr 5, 2005 | 10:17 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: (fcm)
unplug the brain, let it sit for minute...this should clear the brain and maybe it will straighten out. otherwise take it to who sold it and installed it and have them check it out...possible send it out for service (they should give you another one if they're a good shop).
-Chris
Old Apr 5, 2005 | 10:43 AM
I installed it.
I just sent in the remote and antenna for replacement (authorized) so I REALLY dont want to send the brain in for exchange.
I had it sit an entire night, saturday, w/o the battery cable connected.
I'll try that again, but if it doesnt work, I pretty much have to send it in, right? **** the dealer is in Oregon.
Old Apr 5, 2005 | 10:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">I installed it.
I'll try that again, but if it doesnt work, I pretty much have to send it in, right? **** the dealer is in Oregon.</TD></TR></TABLE>
it sounds that way honestly, when we have a bad brain, or a non functional issue. sorry to say that to you.
Chris
mechanix619
Audio / Security / Video
Dec 2, 2010 05:02 PM
menappi
Dec 25, 2006 06:26 AM
GoLowDrew
Jul 22, 2006 06:21 AM
Weston
Jun 4, 2002 05:26 PM
