compustar gone to shit??
Old Feb 10, 2006 | 05:42 PM
riceburnerryan's Avatar
Default compustar gone to ****??
ok so last week i went thru a metal detector and somehow my remote got fucked... well i got a new remote and then today *exactly one week later* my new remote starts freaking out and i pull the battery and quickly replace it. the remote then wouldnt even respond, and my alarm wont arm.. i took it to a compustar dealer and they couldnt get the remote to reprogram to my car.. we also replaced the antennae and still nothing. i can hear the relays clicking, which im told indicates that the remote is programming but isnt responding to the car ... i have no idea whats going on so if any wiring gurus could help that would be appreciated thanks a lot
Forgot to mention when we try to reprogram the remotes all they do is flash the anntenae symbol and then once you hit a button it flashes all the icons and then beeps and thats it..
Old Feb 10, 2006 | 08:21 PM
Default Re: compustar gone to ****?? (riceburnerryan)
bump anyone have an idea??
Old Feb 11, 2006 | 12:44 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
You might want to pull the brain out and send it in. Sounds like there is a internal problem. The shop that you took it to should of been done this. But you might have to have bought it from them.
Old Feb 11, 2006 | 10:24 AM
fcm's Avatar
fcm
Old Fart
First, what model of Compustar, and what model of remote, here are the remotes....
http://www.compustar.com/support_C.htm
Here are the units.....
http://www.compustar.com/products.htm
If you do not see the unit here, look on the brain for a model number, normally CM ****
Also where did you get it, and who installed it?
I have never heard of a remote going bad by going through a metal detector. 94
Old Feb 13, 2006 | 04:41 PM
my model number is the 2WSSR ... ok so the other day i reprogrammed the remote ... or attempted and now my alarm works which im happy about, but my remote doesnt respond to the brain ... and sometimes it does could it be wiring to the antennae?
Old Feb 14, 2006 | 11:08 AM
fcm's Avatar
fcm
Old Fart
Default Re: (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">my model number is the 2WSSR ... ok so the other day i reprogrammed the remote ... or attempted and now my alarm works which im happy about, but my remote doesnt respond to the brain ... and sometimes it does could it be wiring to the antennae?</TD></TR></TABLE> It can be any of a number of things, a bad remote, [receiver gone west], the ant. itself, the ant. connections, or the RF section, [transmitter] in the main brain itself. the first thing I would look at is the ant. plug/s make sure none of the pins are bent out of the way, any other testing needs to be done at a Compustar dealer, We would try another remote, then plug in a new ant., then swap out the brain, to find where the problem is. 94
Old Feb 14, 2006 | 08:05 PM
started to work again... so i donno thanks tho guys
FOUR-G
Audio / Security / Video
Jan 20, 2011 07:28 PM
EeeJayEight
Jun 4, 2007 01:22 PM
Jago
May 14, 2006 11:53 PM
asujzgirl
Jan 12, 2006 11:19 PM
