Compustar 2W900FM-AS problems
Old Jan 25, 2006 | 10:44 AM
scrolanky's Avatar
Default Compustar 2W900FM-AS problems
So I have a 1997 Acura EL. Basically a Civic sedan. I purchased the compustar alarm and starter from a dealer and proceded to have them install it. I picked the car up and all was good. I live in a small town and the shop is about two hours away where I had it installed. On my drive home I stop in a town to fuel up and as I leave the car the interior light stays on. The LCD remote also reports that my driver side door is open. The pin on the door is not stuck in at all so its not that. Also in Valet mode it does not lock/unlock the doors. The second remote would not learn either. I tried that myself and I couldn't get it to work. They ordered me a second remote and I haven't picked it up yet.
I am not sure when I will be going back to the place where I had it installed. Is there anything I can check or do to isolate the problem and maybe fix it.
fcm I know your a master with compustar hope you can help me out.
Old Jan 25, 2006 | 04:17 PM
JDMcb7's Avatar
Default Re: Compustar 2W900FM-AS problems (scrolanky)
sounds like they fudged up the install, or pin switch is bad mostlikey pin switch is bad even though it just "looks" ok
Old Jan 25, 2006 | 04:59 PM
scrolanky's Avatar
Default Re: Compustar 2W900FM-AS problems (JDMcb7)
so the fact it just happened the day i got my alarm installed is a coincidence...how can I check the pin???
Old Jan 25, 2006 | 06:49 PM
suspendedHatch's Avatar
The dome light and door trigger are on the same wire. It sounds like it is grounding out. Dig it out and reinsulate it. Or sometimes a screw or bolt pierces the wire when they're reassembling the interior.
fcm IS the master. I bow to his influence.
Old Jan 26, 2006 | 09:17 AM
scrolanky's Avatar
Default Re: Compustar 2W900FM-AS problems (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">The dome light and door trigger are on the same wire. It sounds like it is grounding out. Dig it out and reinsulate it. Or sometimes a screw or bolt pierces the wire when they're reassembling the interior.
fcm IS the master. I bow to his influence.</TD></TR></TABLE>
Thanks for the advice. I will check it out tonight.
peter_vang
Mar 26, 2010 08:31 PM
nineohtoo
Audio / Security / Video
14
Aug 4, 2009 01:03 PM
xtegb16x
Oct 10, 2008 02:37 PM
truevietluv636
Dec 5, 2007 06:13 AM
eagleclawracing
Aug 4, 2006 11:11 AM
