Component speakers in Integra
Old Apr 30, 2006 | 01:11 PM
Hairy Gorilla's Avatar
Default Component speakers in Integra
Has anyone here installed a new set of component speakers in the front of an integra? Do you have any recommendations on where to leave the crossover? Did the tweeters fit in flush? Did you have to do much fabrication yourself?
Also, what components would you recommend? I just got an Alpine 9857 headunit installed.
Thanks
BTW, 99 GSR
Old Apr 30, 2006 | 03:19 PM
fcm's Avatar
fcm
Old Fart
Default Re: Component speakers in Integra (Tim Maryak)
The stock tweeter location in a g3 teg is just in front of the door handle, there is lots of room to flush mount most tweeters there, there is more then enough room behind door panel to mount most x-overs, as for what component set to get, get the ones you like the sound of. 94
Old May 5, 2006 | 04:45 AM
Electrodynamic's Avatar
I have my tweets mounted in the kicks and the 6.5's in the doors (with fab'd adapter rings). Keeping the tweets as close to your mids helps your sound stage by keeping everything around the same time alignmnent to your ears. Separating the drivers WAY out does nothing but cause a shift in your sound stage usually. Some times you can get away with it, but most of the time it's easier just to keep them close to each other.
Old May 5, 2006 | 08:56 AM
fcm's Avatar
fcm
Old Fart
Default Re: (Electrodynamic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Electrodynamic &raquo;</TD></TR><TR><TD CLASS="quote">I have my tweets mounted in the kicks and the 6.5's in the doors (with fab'd adapter rings). Keeping the tweets as close to your mids helps your sound stage by keeping everything around the same time alignmnent to your ears. Separating the drivers WAY out does nothing but cause a shift in your sound stage usually. Some times you can get away with it, but most of the time it's easier just to keep them close to each other.</TD></TR></TABLE> Ditto the above that is why a "point source", [like a coax but with a better tweeter and x-over] speaker works so well.
Tim Maryak
Here is a pretty good one... http://www.eclipse-web.com/point/sp6500.html
and go here and find the HI-ENERGY coax HCX 165 an over-sized 6.5" 2way speaker... http://www.hertzaudiovideo.com/default_en.htm sorry can't link you directly to it, but if you have money burning a hole in your pocket check them out, and if it's a lot of money, check out the MILLE line. 94
Old May 6, 2006 | 01:54 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
a good spot to put the crossover is in the door pannel. There is a little black cup or box that the x-over should fit in to. Plus it will keep the x-over out of the way of the window and keep it from getting wet. gl
Old May 7, 2006 | 01:14 PM
shyboy817's Avatar
Default Re: (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">a good spot to put the crossover is in the door pannel. There is a little black cup or box that the x-over should fit in to. Plus it will keep the x-over out of the way of the window and keep it from getting wet. gl</TD></TR></TABLE>
If you haven't got component set yet, MB Quart x-over's won't fit here, tried it .. sucks
deeweezy187
Oct 1, 2007 02:31 AM
watacivic
Audio / Security / Video
Nov 19, 2006 10:46 PM
sinister357
May 31, 2005 07:53 PM
ALF
Apr 15, 2003 03:52 PM
acuraLSSE95
Jan 1, 2002 06:41 PM
