Code Alarms?
Old Aug 9, 2005 | 03:23 PM
PooM's Avatar
Default Code Alarms?
What do you think of these alarms, are they any good? Or is there anything better?
Old Aug 9, 2005 | 04:14 PM
junior40er's Avatar
Default Re: Code Alarms? (PooM)
these alarms eat ****. I used to be an installer at circuit city and they suck. Always came back for repairs thats why circuit city got rid of them. they suck. your better of with downtown la alarms.
Old Aug 9, 2005 | 04:47 PM
PooM's Avatar
Default Re: Code Alarms? (junior40er)
Thanks for letting us know. I am from the UK, so cant get to LA that easy
What makes do ya recommend?
Old Aug 9, 2005 | 08:02 PM
erikiksaz1's Avatar
I had one on my old hatch and it worked most of the time. There was one instance when it was having some issues, but after bringing it back to the installer, all was well.
Old Aug 10, 2005 | 05:02 AM
vicn77's Avatar
code alarms aren't bad as long as they are programmed correctly. i've had one on my accord for over 3 years now and haven't had any problems. i work at cc and yes we've had problems with them but they were all fixed with proper programming.
Old Aug 10, 2005 | 10:19 AM
rjr162's Avatar
Default Re: Code Alarms? (vicn77)
yes-- programming is key.
I'd also recommend if you're doing a unit with the master module, disable the internal shock sensor. The thing is a peice of crap and falses like nothing else. We did this for all of our customers and used the add-on external shock sensor instead with no issues. I think there was one other issue with them, I can't remember off of the top of my head, but it was something minor and may have just been more of an annoyence than anything else.
The code alarm door interface (DEI 451M equiv) was nice. Any dodge or other vehical that needed resistors to interface the door locks.. all you had to do was open the module, cut the jumper wires, and turn these two variable resistors to the ohms required, and bam, you're done.
Old Aug 10, 2005 | 10:43 AM
fcm's Avatar
fcm
Old Fart
There are lots of good alarms out there, and some real bad ones, but if you stick with a brand name, and Code Alarm is one of them, any DEI alarm, http://www.dei.com or Compustar, http://www.compustar.com you should be fine, most problems with alarms has more to do with the install, [and programing is part of that] then the alarm itself. 94
Old Aug 10, 2005 | 06:32 PM
erikiksaz1's Avatar
Default Re: Code Alarms? (rjr162)
Ahh yes, the shock sensor. That POS would go off at the smallest instance of a low frequency noise. Even at the lowest settings, any car with a modified exhaust (legal noise limit) would set it off.
Old Aug 11, 2005 | 03:11 AM
rjr162's Avatar
Default Re: Code Alarms? (erikiksaz1)
hell i swear sometimes it would go off without even any vibrations. I had heard that the issue was the warn away and the set off couldn't be within 10 settings of each other or it would false... but i swear it didnt' matter what you had them set to.
Old Aug 12, 2005 | 03:58 PM
junior40er's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PooM &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for letting us know. I am from the UK, so cant get to LA that easy
What makes do ya recommend?</TD></TR></TABLE> VIPER all the way. Trust me on this they are the ****. (in a good way). I only install viper alarms on the side cause I never got to deal with them coming back for a malfunction. If I installed code alarms instead I wouldnt make money. GO WITH VIPER
paddydisaster
Audio / Security / Video
Nov 1, 2008 09:40 AM
GarageAlchemist
May 31, 2007 05:44 AM
joenoreason
Jan 20, 2007 03:17 PM
hondaracer4vtec
Jan 26, 2006 06:32 PM
BlingBlingCivic
Nov 25, 2001 03:27 PM
