Cluster wiring/AF gauge problems
Old Mar 18, 2007 | 11:57 AM
dc2_dude's Avatar
Default NEED help ASAP
ok i have a 99 gsr. i just hooked up my autometer a/f gauge the other day. it was working fine. but then i just got my cluster in the mail yesterday, so i go to put it in, i wire it back up everything works. then smoke comes pouring out. the gauge power and ground were wired into the power and ground on my radio and the o2 was ran to the ecu. well all the wires to the gauge melted..so i immediatly unhookend them. now my radio doesnt work. i used my volt meter and im not getting any power to the wires. i checked the fuses they all seem to be fine..is my radio fried??? or would it be the wires?? help please quick
Old Mar 18, 2007 | 12:20 PM
B18C_EJ8's Avatar
Did you check the backup fuse under the hood & the radio fuse under the dash?
And by "they seemed fine" do you mean that you verified they were good with your meter?
Old Mar 18, 2007 | 01:41 PM
dc2_dude's Avatar
they didnt look blown. i didnt check them with the meter..but im going to get new fuses now..and switch them just in case. i checked both underdash and underhood they looked not blown
Old Mar 18, 2007 | 02:05 PM
94_DC4's Avatar
Default Re: (2literteg)
Test the fuses for continuity.
Old Mar 18, 2007 | 03:57 PM
dc2_dude's Avatar
i tested it on ohms and it read like 5 ohms shouldnt it be ofL? i replaced all the fuses still no power to the gauge or radio
Old Mar 18, 2007 | 04:28 PM
fcm's Avatar
fcm
Old Fart
You have probably damage some wiring, test for power, [DC volts] on the stock radio harnesses yellow/red it is switched, hot when ign, switch in in acc. or run and the white/yellow it is constant power, hot at all times.
Check for power at the radio fuse in the under dash fuse box, hot when ign. switch is in acc. or run and the backup power fuse in the under hood fuse box, check your main fuses in the under hood fuse box. 94
Old Mar 18, 2007 | 05:32 PM
dc2_dude's Avatar
alright i'll try that tom. thanks..also im gona use a test light to see if im getting power to those fuses
Old Mar 18, 2007 | 08:11 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Your going to have to pull the wire harness out of the car and fix all those dam wires in the harness. I just fixed one in a members car. What cluster were you trying to use that caused this. One thing I would check all the fuses in your car and make sure the right amp fuse is put in the right spot. The problem sounds like that you replace a burnt fuse before with a higher amp model then the one that was in it to start with. Thats why the fuse did not blow when it was overloaded.
Old Mar 19, 2007 | 06:19 PM
dc2_dude's Avatar
ok i checked everything i replaced all fuses with correct sizes one of them under the hood was a 10 instead of 7.5 i changed that. i used a test light to check power..the back up radio fuse had power. but the radio fuse under dash and cig. lighter fuse had no power. thing is my cig. lighter still works b/c my phone charger works..but still no power.. Now do i pull the harness that goes to the radio's harness..and do i have to take the dash out. if someone could help me out through the steps of what i should do that would b great. i really dont wanna take it somewhere. and i was hooking up a air/fuel gauge (replaced dimmer switch with that.
Old Mar 20, 2007 | 05:13 AM
jz98ctr's Avatar
Default Re: NEED help ASAP (2literteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2literteg &raquo;</TD></TR><TR><TD CLASS="quote">ok i have a 99 gsr. i just hooked up my autometer a/f gauge the other day. it was working fine. but then i just got my cluster in the mail yesterday, so i go to put it in, i wire it back up everything works. then smoke comes pouring out. the gauge power and ground were wired into the power and ground on my radio and the o2 was ran to the ecu. well all the wires to the gauge melted..so i immediatly unhookend them. now my radio doesnt work. i used my volt meter and im not getting any power to the wires. i checked the fuses they all seem to be fine..is my radio fried??? or would it be the wires?? help please quick</TD></TR></TABLE>
why does everyone use the radio wiring for aftermarket stuff besides radios???? everyone tries to tag 2 or 3 different things onto a power wire that barely has enough current to run 1 accessory...nevertheless 2 or 3.
you said you're not getting power to the radio wiring right???
trace back to your fusebox and double check all your fuses for continuity with a meter....not by eye! if all your fuses (underdash and underhood) are A OK...then you might've very well melted the wiring and would need to run new wires for power and ground and everything else. just make sure you fuse as close to the power source as possible! not close to the accessory you are hooking up!
you might've very well cooked the radio. only one way to tell for sure...smell it.
Old Mar 20, 2007 | 05:21 AM
fcm's Avatar
fcm
Old Fart
If you do not have power at the radio fuse, [when ign. is on to acc. or run] the problem is not between the fuse box and radio, it is between the ign. switch and the fuse box, check the yellow wire in ign. switch harness, [plugged into fuse box] for power when ign. switch is in acc. and run. 94
Old Mar 20, 2007 | 08:04 AM
dc2_dude's Avatar
god i hate all this wiring ****. ok i'll check all of those. so basically im gonna have to take it somewhere and have a new harness ran? f*ck
Old Mar 20, 2007 | 08:05 AM
jz98ctr's Avatar
not necessarily.
but also not totally out of the question either.
do a little testing before you go and drop coin on unneeded parts.
Old Mar 20, 2007 | 11:00 AM
dc2_dude's Avatar
ok i kno what the problem is the hole radio harness from the fuse box to the radio is bad. my friend has one that im getting in a week or so when he strips his car. meanwhile i straight wired it to the battery with a switch (ghetto) i kno but i need a radio for 5am drives to work
Old Mar 20, 2007 | 11:17 AM
Get that harness from your friend and fix it right. You do not know what other wire has been damage from the wires getting hot and melting. When I repaired the other members car there was 4 other wires that were really bad and needed replacing. You could just fix that problem but anothor could lie ahead later.
Old Mar 20, 2007 | 02:08 PM
dc2_dude's Avatar
yea the dash is coming out soon for RHD conversion so, i'll probably replace the whole harness. hopefully my front clip comes with one. i'd imagine it would
Old Mar 21, 2007 | 08:39 AM
suspendedHatch's Avatar
Or you could pull the damn harness out and fix the wires individually. I did it on my last car. Being that it was an EF Si, the harness was hard to find/expensive.
Please don't make another topic with a generic post title. It makes the search function useless.
dlinm
Jun 1, 2007 03:49 PM
NobodySpecial
Jan 7, 2005 11:22 AM
SnowSurfer
Jun 20, 2004 08:08 AM
CMCivicSI
May 20, 2004 04:24 PM
LOwrestling2001
May 31, 2002 05:11 AM
