Clifford G4 programming help
I need help with programming a feature on the clifford g4, specifically the solaris owners manual, i can't post it up because it's in pdf format, but you can get a copy of it through clifford website. I need to know how to programm the chirp feature so that when i arm and disarm i can hear the 1 or 2 chirps. I've read and reread over 10 times page 11-12 directing me how to program it but somehow i can't get to work. i am stuck on step 6 page 11, it doesn't state how to turn on or off, just that 2 chirps means on and 1 chirp is off...plz help dear members? thanx
im not looking at the manual but that option is preset i believe. the dark highlighted is what it is preset at.. and it should be preset to the normal 2 beep (alarm on) one beep (alarm off)
if its not and its reversed then get into the installer program feature and push the approprite column/row and then once your in the correct column/row. push the arm/disarm button once.then turn key to off.
then test.
if it didnt work do it again and when you push the arm/disarm again it will be either 1 or 2 chirps ( if the first time doing gave you 1 chirp then make sure the second try is 2 chirps)
then test.
whiteef-8
Audio / Security / Video
May 14, 2008 06:18 PM
acuraLSSE95
May 31, 2004 10:22 PM
