Clifford Alarm Problem
Old Jul 31, 2006 | 08:51 AM
mzaner's Avatar
Default Clifford Alarm Problem
I have a Clifford Matrix 2.5x alarm system. My car alarm isn't arming anymore. I know because I got inside, pressed the arm button and tried starting the car, but the alarm didn't go off and the car started. When I press the arm button the doors lock and everything but it pages my remote and tells me that the car or the brain isn't receiving the signal. Does anybody know how to make it arm again?
Old Jul 31, 2006 | 09:29 AM
B18C_EJ8's Avatar
What's the LED doing?
Old Jul 31, 2006 | 09:38 AM
mzaner's Avatar
Default Re: (B18C_EJ8)
It is constantly on, but when I start the car it goes off. When I press the arm button the LED doesn't even blink or anything, it just stays on.
Old Jul 31, 2006 | 09:52 AM
B18C_EJ8's Avatar
It's probably in valet mode. I forget how to get it out of valet mode, but I'm sure it's in your instruction manual..
Old Jul 31, 2006 | 10:01 AM
mzaner's Avatar
It says to press the Valet button and I've already tried it. Whenever I press it, it doesn't do anything, so I made sure it was connected to the brain and it was. Shouldn't the alarm still arm though if it's in valet mode?
Old Jul 31, 2006 | 10:15 AM
B18C_EJ8's Avatar
Instructions say to turn the ignition to the "On" position, then turn it off. Then press the button.
You can also take it out of valet mode with the transmitter by opening a door, pressing lock, then unlock, then lock again... Light should go out and all should be well...
Old Jul 31, 2006 | 10:16 AM
B18C_EJ8's Avatar
And no, the system should not arm in Valet mode...
Old Jul 31, 2006 | 10:27 AM
mzaner's Avatar
Ok, thanks for your help, will try the Valet mode thing and repost if I'm still having the problem.
Old Jul 31, 2006 | 03:08 PM
B18C_EJ8's Avatar
Well?
Old Aug 1, 2006 | 10:01 AM
mzaner's Avatar
Oh, I IM'ed you yesterday, but I guess you never got it. After I went out and tried that it armed and disarmed and now it's working fine. Thanks for your help. BTW do you have the manual or a link to DL it for the 2.5x? I looked at the Clifford site, but couldn't find it.
Old Aug 1, 2006 | 11:36 AM
fcm's Avatar
fcm
Old Fart
Default Re: (mzaner)
Do you need the install guide... http://www.directeddealers.com...4.pdf
or the owners guide... http://www.directeddealers.com...4.pdf 94
jmacsss
Audio / Security / Video
Jun 15, 2012 02:05 AM
mechanix619
Dec 2, 2010 05:02 PM
ohsnapzafingcu
13
Feb 9, 2009 11:46 AM
Dr. Willy
Aug 11, 2008 12:53 AM
eL
Jun 27, 2004 07:39 AM
