cd player won't work....
Old Jan 8, 2008 | 11:19 PM
methos713's Avatar
Default cd player won't work....
m cd player has been acting up. It seems to be the wiring harness. If the harness moves, the cd player won't come on. I checked all the fuses and they seem to be okay. I also checked the ignition and ground w/ a multimeter....it gets power.
The wires don't seem to be touching...cause I have my shiftlight connected to the power and ground wires...and it works. So when turning the car on, the only thing that doesn't come on is my cd player. Any help and suggestion would be appreciated. TIA.
Old Jan 9, 2008 | 08:07 AM
alex801to410's Avatar
Default Re: cd player won't work.... (methos713)
First off I need to know what kind of car and cd player you have to really give you an answer. You could check the fuse on the radio itself, or the connections on the accy, 12vt and ground wires too.
Old Jan 9, 2008 | 10:23 AM
methos713's Avatar
Default Re: cd player won't work.... (alex801to410)
Its a pioneer deck...DEH-P7700MP. Using it in my 95 honda civic. I checked the fuse on the deck, its okay. The deck also has a new wiring harness I bought from Best Buy, since the old one wasn't good...and it needed a sub-harness(I think that's what you call it) that my factory harness needs to connect to so it can connect to the deck harness.
I'll try to post a pic up of the wiring this weekend since I'm working out of town.
Old Jan 14, 2008 | 12:39 PM
hoenstly it wouldnt be a fuse if it came on at all. I would re do the 12vt (yellow), accy (red), and the ground (black) connections. Sometimes they will still read the correct voltage.
Old Jan 14, 2008 | 04:10 PM
fcm's Avatar
fcm
Old Fart
Check the backup power fuse, normally in engine bay fuse box and normally a 7.5A it powers the yellow constant power lead. 94
Old Jan 14, 2008 | 05:58 PM
methos713's Avatar
Default Re: cd player won't work.... (fcm)
okay, I'll check on those. What if nothing is wrong with that fuse and how do I go about re-doing the 12vt, accy, and ground connections??
Old Jan 15, 2008 | 05:41 AM
White Smoke's Avatar
i my honda
Global Mod
I don't think you will have to re-do the wires unless there damaged. Are you getting 12volts at both the the acc and ignition wire going to the CD player? If so then thats probably not your problem. Check and make sure you have a good ground as well.
C8V6C
Audio / Security / Video
Jun 4, 2010 10:10 AM
mrmcnotbuff
Feb 17, 2008 06:06 PM
sickazzcivic69
Nov 27, 2005 06:35 PM
ineedmoney
Jun 3, 2004 06:28 PM
damion911
Mar 3, 2004 11:14 AM
