CD Player Power Issue
Old Mar 16, 2007 | 01:58 PM
texas_tea_2k6's Avatar
Default CD Player Power Issue
I just finished installing my cd player in my car. For some reason everytime i start my car my settings are not saved on the cd player. I have to adjust it everytime. I even have to manually turn on the cd player each time. I just want some tips on what it could be. Could it be a fuse or something?
ANY TIPS PLEASE MESSAGE ME. THANX
Old Mar 16, 2007 | 02:06 PM
B18C_EJ8's Avatar
You either have a blown fuse on your constant power wire or you have it hooked up incorrectly.
Check the radio fuse under the hood...
Old Mar 16, 2007 | 02:25 PM
Default Re: (B18C_EJ8)
the fuse is good, thinking about it the cd player wouldnt power on if the fuse was bad anyways.
What do u mean fuse on the the constant power? How can i find this out?
Something that seems weird, i have the red, yellow, and white w/ ??? stripe. This is the only way the deck powers on. (all the wires have to be connected together)
Old Mar 16, 2007 | 02:27 PM
B18C_EJ8's Avatar
Yes it would.
There are two fuses for the radio. One under the hood & one under the dash.
You would check this out using a multimeter or a test light.
Old Mar 16, 2007 | 02:30 PM
Thats weird, let me tell u, i have a 94 honda civic. I looked under the hood and seen no radio fuse. Only one I seen is under the dash. Ill double check though
Old Mar 16, 2007 | 06:27 PM
fcm's Avatar
fcm
Old Fart
Default Re: (texas_tea_2k6)
It is a 7.5A fuse, [DO NOT replace with a larger fuse, it is not marked as radio, probably BACKUP PWR, it is hot at all times. 94
Old Mar 16, 2007 | 08:07 PM
01d17's Avatar
Default Re: (fcm)
dont run the yellow and red on the harness together. your problem lies in the red wire which is meant for switched 12V aka memory. You need to tap into the yellow/red wire if the factory wiriing is still there. if not you need to find a power source that only shows 12 volts when the vehicle is on.
Old Mar 16, 2007 | 09:36 PM
Default Re: (01d17)
THANKS FOR THE TIPS YOU ALL I WILL REPLACE THE FUSE TOMORROW AND TRY REWIRING. ILL UPDATE MY INFORMATION AS SOON AS I GET A CHANCE. GOOD LOOKING OUT YOU GUYS.,
HAVE A GOOD 1 4 NOW
Old Mar 17, 2007 | 05:44 AM
fcm's Avatar
fcm
Old Fart
Default Re: (01d17)
" red wire which is meant for switched 12V aka memory" that's a typo, right? 94
Old Mar 17, 2007 | 06:06 AM
Default Re: (fcm)
memory would be yellow. coming to find out that (backup) fuse was bad
Old Mar 17, 2007 | 06:54 PM
Default Re: CD Player Power Issue (texas_tea_2k6)
K i did it and everything turned out for the best. Thanks every1 for there input. God Bless.
immrtaltchnq
Audio / Security / Video
Jul 18, 2009 10:01 PM
DarkBB4
Mar 7, 2005 03:45 PM
xSCTYGx
May 31, 2004 08:44 AM
NiCkArInO
Aug 21, 2003 04:41 PM
