CD Player Bounce!!!
Old Mar 15, 2002 | 09:41 PM
MaD3 In JaPaN's Avatar
Default CD Player Bounce!!!
I was coming out of a parking lot, so i gunned it in first, and shifted to 2nd and the car bounced a little bit, but my cd player ended up bouncing too........i parked at the mall parking lot, and then left, when i came back, i tried to turn my cd player on but it wouldn't, the eject works fine but the cd player would not turn on, only if i pressed eject and it ejected my disc then would immediately turn off again........Any ideas on what u think happened?????????? think it short circuited my cd player??? but don't really know.....
Old Mar 16, 2002 | 06:29 AM
thefordmccord's Avatar
Default Re: CD Player Bounce!!! (New2HD)
can you normaly eject cds when the key is turned off?? What kinda cd player is it?? It just sounds like the power lead that comes from the key switch has come loose...
Old Mar 16, 2002 | 12:12 PM
CRXican's Avatar
Default Re: CD Player Bounce!!! (thefordmccord)
Ya, try checking the wiring cause it can get tight in the small space behind the head unit. It's likely that one of your wires got disconnected.
Old Mar 17, 2002 | 07:58 AM
Default Re: CD Player Bounce!!! (CRXican)
i kinda thought one of the wires is loose.....i'll retighten all of them just incase.....cuz i'm rolling musicless now and come close to falling asleep sometimes.......
Old Mar 17, 2002 | 10:36 AM
alright i just went in there....i cut off all the wires and rewired them, i put electrical tape on every single wire........and hooked it back up to my car.....and same thing happened....only the eject works it will not turn on......so i took the original tape player the car had and i hooked it up to the car, and it does the same thing as he original cd player.....uugghh things pissing me off.......both of them won't turn on!!!! i think it's the original wiring of the car...........and info would help!!!!this craps getting pretty annoying!!!
Old Mar 17, 2002 | 01:41 PM
3RROR404's Avatar
Have you checked your fuses yet?
You've obviously ruled out the deck, by getting the same results from another unit. Sounds kind of like you are getting memory power, but not switched/ignition power. To try and single out the problem, hook your old deck up only unsing the two power wires and ground, no speaker or remote turn-on. Check all your fuses and power connections with a multimeter. GL
Dennis Melnyk
Mar 15, 2019 08:57 PM
jdmcd7_cali-luv
Dec 19, 2008 02:05 PM
RSpesher
Jun 2, 2008 10:38 AM
digitalh3lix
Audio / Security / Video
Jan 14, 2005 02:46 PM
