CD deck power issue
Old Jan 20, 2007 | 02:27 AM
AntiochOG's Avatar
Default CD deck power issue
On days when it is really cold outside my cd deck turns off about 5 seconds after I turn off my car. Anybody heard of this? It is actually kind of cool, but what would be causing this to happen?
Old Jan 20, 2007 | 08:10 AM
fcm's Avatar
fcm
Old Fart
Default Re: CD deck power issue (AntiochOG)
A defective diode between the acc. 12V+ and constant 12V+ in the HU itself could cause it, you would need to check the acc wire going to the HU to see if it is still hot when ign. is turned off, if it does test as hot unplug it from the HU and test again, if still hot and HU turns off the problem is in the car, if the HU stays on the problem is in the HU, keep in mind you are only disconnecting the acc. lead. 94
CubbyChowder
May 17, 2010 10:54 PM
mcgee*
Audio / Security / Video
Jan 29, 2006 10:09 AM
hale_image
Dec 15, 2004 10:35 PM
CRX7
Oct 3, 2003 06:59 AM
