CB question.
Old Dec 17, 2008 | 07:01 AM
kidwit93delsol's Avatar
Default CB question.
Ok. Stepping away from the Sol. I'm putting a CB in my truck. My question is about the atennaa. I have one that is roughly seven feet tall. Can I run it through the frame so I can keep my stock look? I also thought about just mounting it under the truck, but I also go offroading and dont want it to get ripped off.
Old Dec 17, 2008 | 11:14 AM
fcm's Avatar
fcm
Old Fart
LOL, under the truck, no.
Your CB ant needs to be mounded vertically, must be grounded properly and the SWR "tuned" properly, if not done properly at the very least you will have poor reception/transmission, at worst you can blow the output. 94
Old Dec 18, 2008 | 07:43 AM
Laughing at me? Hey could only hope the best. What if I mount the base to a steel bracket I fabricate under the truck and run the antenna between the cab and the bed? I think it might be too tall so can I bend it and mount it to the tonneau cover? I see some trucks with the antenna bent like I'm saying. But 94 said vertical...
Old Dec 18, 2008 | 11:06 AM
fcm's Avatar
fcm
Old Fart
Best bet, replace the the ant. with a roof mount.
You could do the "between box and cab" if height is not an issue, but bending it will only effect range for both reception and transmission. 94
Old Dec 18, 2008 | 04:46 PM
vw eater's Avatar
do they make a small antena?one for a honda that dosent look all crazy?also can you use the same speaker for you alarm as the cb/pa? thznks
Old Dec 18, 2008 | 05:19 PM
fcm's Avatar
fcm
Old Fart
CB ant. come in all sizes, for a CB to work properly, [transmit] it has to be a proper CB ant. designed for the CB you have and it must be installed and connected properly, read... http://home.att.net/~wizardoz/cbmw/antenna_fabri.html.
No you can not use your siren as a PA horn. 94
Old Dec 19, 2008 | 08:02 AM
vw eater's Avatar
ok thanks
Old Dec 19, 2008 | 11:57 AM
mrdeadman's Avatar
They let me pick
7 feet long is pretty damn long.
Old Dec 20, 2008 | 08:03 PM
White95SiHB's Avatar
No joke, they really are tall.
My dad used to have a K40 antenna 20 years ago, I do remember it being pretty tall.
Everytime he'd go in a parking structure he'd have to stop and unscrew it from the base. LOL
4n_intelligence
Jun 21, 2009 12:00 PM
4drsedaneg
Welding / Fabrication
May 27, 2008 06:36 AM
GapxGuy
Mar 19, 2005 12:01 PM
92civeg
Feb 19, 2004 12:04 PM
Floyd
May 23, 2002 01:30 PM
