CALLING ALL Electrical/Security Teg experts...
Old Jun 24, 2002 | 07:52 PM
integra-modder's Avatar
Default CALLING ALL Electrical/Security Teg experts...
Im going to be installing a clifford AG4 alarm.
I need to know the following...
1.Do I have Heater A/C, Heater 2, and Ignition 2 wires from the ignition switch? (i dont think so)
2.Where is the closest/easiest place to get access to the Door Lock/Unlock AND Window Up/Down wires?
3.Are the integra power door systems normally closed or normally open systems?
Clifford Alarm Install Help
Steps required to start a car that is installed as a manual tranny:
FOR ALL MANUAL TRANS MISSIONS, PER FORM THE FOLLOWING STEPS:
1) Start the car using the ignition key.
2) Set the emergency brake.
3) Set the heat or AC to ON.
4) MAKE SURE THE CAR IS IN NEUTRAL.
5) Transmit the manual transmission enble function by pressing button 11 on the master remote control.
6) Turn the key OFF and exit. The car stays running.
7) Close all doors, arm the alarm. The engine stops running. You are now in manual transmission mode.
8) Provided the doors are never opened or the alarm is not triggered, the remote start func tion will start the vehicle’s engine. If a door is opened or if the alarm is triggered, manual transmission mode is canceled.
9) Press button 4 on the master remote or the * button on the companion remote to start the engine.
Steps required to start a car installed as an automatic tranny.
1) Press button 4 on the master remote or the * button on the companion remote to start the engine.
so I want to install this onto my stick car, but use the automatic installation way. Is it possible for it to still look make it look for the ebrake in order to start?
Clifford AG 4 Installation Manual
Old Jun 24, 2002 | 08:33 PM
Default Re: CALLING ALL Electrical/Security Teg experts... (EVIL Teken)
EVIL Teken: Ignition 1 is for primary ignition operation... Ignition 2 is for a secondary ignition operation such as Nissans. It is also used to power heater, A/C
because some vehicles have those circuits seperately fused...
EVIL Teken: From the driver side door panel...
EVIL Teken:
EVIL Teken: No... Do not assume you know better than the engineer who built the starter unit... If you have a 5 speed vehicle, apply and install the unit as per the manufactures instructions and programming guide...
A 2700 lbs object can, and will, cause more damage than your body can repay...
I will be using the manual installation method provided in the book.
Are the doors being normally open or closed...
[Modified by integra-modder, 1:07 AM 6/30/2002]
Old Jun 24, 2002 | 08:50 PM
t's Avatar
t
Default Re: CALLING ALL Electrical/Security Teg experts... (integra-modder)
you didnt answer the fact of the doors being normally open or closed...
I would assume you would want your doors closed for your alarm to be effective
Old Jun 24, 2002 | 08:58 PM
99VTECex's Avatar
New User
How do you look at that as that many steps? OK:
STEP 1: Start car --- well your car is already running
STEP 2: When you are ready to leave the car set the emergency break -- you should do that anyway
STEP 3: Set the Heat or AC -- well you have to do that if you want that to work for any remote starter
STEP 4: Car in Neutral -- well you should do that too especially if you want RS on a 5spd
STEP 5: Push button II on master -- ok so at this point you have done one thing extra
STEP 6: Turn key off and exit. -- hey what a great idea
STEP 7: Close doors -- there's a start -- Arm the alarm -- you should do that anyway
STEP 8: If you don't get anything from your car while you are a) in a store b) at work c) sleeping at night d) all of the above e) none of the above then you are all set
STEP 9: Push a button to start car -- well at this point you are now starting the car after you have done either A, B, C, D, E from above.
So we can recap in to 3 easy steps
Revise STEP 1: Drive car, when done get out of car like you normally do, LEAVE IT IN NEUTRAL
Revise STEP 2: Push a single button and get out of car, and ARM it like you do anyway
Revise STEP 3: Do A, B, C, D, or E (from above) now push the button when you get back to or wake up, to start it.
So you are telling me that from 9 steps to 3 steps and the ONLY thing EXTRA/DIFFERENT that you are doing is pushing one button to enable the RS. and then there is a whole extra step (original step 9) to start the car.
Sounds like cake to me. Do it. Good luck.
[Modified by 99VTECex, 1:00 AM 6/25/2002]
Old Jun 24, 2002 | 09:14 PM
Default Re: CALLING ALL Electrical/Security Teg experts... (99VTECex)
ok
anyone know if the doors on tegs are normally open or normally closed?
Old Jun 25, 2002 | 07:09 AM
ttt
Old Jun 25, 2002 | 10:02 PM
B18C1 for fun's Avatar
what do you mean normally open or closed? They have a negative trigger meaning the doors ground out when they are open.
Old Jun 26, 2002 | 08:05 AM
Default Re: CALLING ALL Electrical/Security Teg experts... (ForceFedGSR)
the circut for opening and closing doors, is it normally open or normally closed?
Old Jun 26, 2002 | 08:09 AM
just found this:
Determining the Door Lock System Type
1. Remove the door lock switch on the driver’s side of the vehicle to reveal the switch wires.
a. If there are four or more wires, make the connections shown in Diagram 4 for reverse polarity.
b. If there are three wires, proceed to step 2.
c. If the vehicle is a Nissan and it does not have a door lock switch, find the single wire in the driver’s kick panel that shows ground when the locks are unlocked and “open” when the locks are locked. Cut this wire and make the connections shown in Door Lock/Unlock Diagram 3.
2. Connect the negative voltmeter lead to ground and probe each wire while locking/unlocking. If the voltmeter show +12v while activating the switch, make the connections shown in Door Lock/Unlock Diagram 1 for positive trigger. Otherwise, go to step 3.
a. On systems without lock/unlock relays (Arrow 3, etc.) you must program for positive door locks (factory setting is negative) when the system has been powered up.
3. Repeat step 2 with the negative voltmeter lead connected to +12v. If the voltmeter shows +12v whi e activating the switch, make the connections shown in Door Lock/Unlock Diagram 2 for negative trigger.
4. Locks controlled from the driver’s door key require installation of just one #60-516 servo in the driver’s door. Vehicles without factory power locks require a servo in each door. Mount the servo(s) and make the connections show n in Door Lock/Unlock
Diagram 5 for adding servos.
5. On a vacuum-pump-type Mercedes Benz or Audi, make the connections shown in Door Lock/Unlock Diagra 6, then (if 1989 or older) program the system for a 3-second lock pulse.
6. Clifford systems can also provide two pulses (+ or -) for lock and/or two pulses (+ or -) for unlock required by some vehicles (such as some Nissans, VW’s, and Audis). Wire the door locks following the steps above and select the 2x lock or unlock feature in installer-programming.
Old Jun 26, 2002 | 08:20 PM
t's Avatar
t
Hook your ground wire to the commons and the N.O. to the door locks.
Old Jun 26, 2002 | 08:38 PM
nsxxtreme's Avatar
Default Re: CALLING ALL Electrical/Security Teg experts... (t)
I would follow this advice. I built a sensor that would tell if the car was in gear. Well it worked for two years. Then it failed now I have a hole the size of my car in the wall in my garage. I am still determined to defeat this but more engineering work by me is needed. I have heard of to many accidents to recommend anyone to try and defeat this.
[Modified by nsxxtreme, 9:38 PM 6/26/2002]
Old Jun 27, 2002 | 06:57 AM
Default Re: CALLING ALL Electrical/Security Teg experts... (nsxxtreme)
I changed my mind already and am doing it the correct way. After I thought about it, Its not worth the chance of an extra seconds worth of time and maybe .01 cents of fuel each time rather than a few grand in repairs.
Old Jun 27, 2002 | 07:33 PM
99VTECex's Avatar
New User
what year is your teg?
Old Jun 28, 2002 | 10:06 PM
redazn72's Avatar
on the integra the door lock system is a 201 system ( negative door lock ) if you use a test ligth on your door locks.... it should give you a negative signal when you press lock or unlock on your car,...
Old Jun 29, 2002 | 07:02 AM
Default Re: CALLING ALL Electrical/Security Teg experts... (redazn72)
2001
so does that its normally open?
Old Jun 29, 2002 | 08:49 PM
kwhitelaw's Avatar
Tape off the gray/orange and gray/green wires. You won't use those. Hook up the red/green and red/orange to ground. Hook up the white/green and white/orange wires to your doorlocks.
Old Jun 29, 2002 | 09:06 PM
Default Re: CALLING ALL Electrical/Security Teg experts... (kwhitelaw)
are you sure these arent reversed? cuz id figured that the red/grn and red/org are to the door locks and the white/green and white/orange to the grounds.
Old Jun 30, 2002 | 08:09 PM
H22g2Integra's Avatar
The last post is correct. Your car has negative trigger door locks and the alarm has onboard relays which do three different lock and unlock set ups. So if they are negative you have to ground the 86 and 87 of the diagram and hook up the 30's of the alarm to the dook locks the other two wires are not needed. Hope that helps you out.
Old Jun 30, 2002 | 09:37 PM
Default Re: CALLING ALL Electrical/Security Teg experts... (H22g2Integra)
wtf? im lost!
where are you getting 86,87, and 30 from?
Old Jun 30, 2002 | 09:57 PM
STK B16's Avatar
here is full steps where ur wires are.. for 2001 integ
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| POWER LOCK|black/white |- |drivers kick panel *2 |
| POWER UNLOCK|black/red |- |drivers kick panel *2 |
| LOCK MOTOR|white/red | |driver kick panel |
| UNLOCK MOTOR|yellow/red | |motor in driver door |
| DISARM DEFEAT|yellow/red | |driver kick panel |
| PARKING LIGHTS +|red/black *3 | |grn plug above fusebox |
| PARKING LIGHTS -|green/yellow | |factory alarm (if equipped) |
| HEADLIGHTS|red/wht (low) 12awg|+ |steering column |
| DOOR TRIGGER|lt. green/red *4 |- |drivers kick panel *2 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|green |- |*6 |
| HOOD PIN|yellow/red |- |drivers kick panel |
|TRNK/HTCH RELEASE|blue |- |at switch *7 |
| FCTRY ALARM ARM|factory remote only | | |
|FCTRY ALRM DISARM|factory remote only | | |
| TACHOMETER|blue | |distributor *1 |
| SPEED SENSE|orange | |instrument cluster |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|gray or blu/grn |- |steering column |
| WIPERS|blue & blu/yel *5 |- |steering column |
| LF WINDOW UP/DN|red/blu - red/yel |A |in drivers door |
| RF WINDOW UP/DN|blu/yel - blu/grn |A |in drivers door or dkp |
| LR WINDOW UP/DN|green - grn/yel |A |in drivers door or dkp |
| RR WINDOW UP/DN|yel/grn - yellow |A |in drivers door or dkp |
| SUN RF OPN/CLOSE|grn/red - grn/yel |A |sun roof switch |
| RADIO 12V|white/blue |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/red |+ |radio |
| RADIO ILLUMINATE|red/black |+ |radio |
| POWER ANTENNA|yellow/green |+ |radio |
| LF SPEAKER|blu/grn - gry/blk | |radio |
| RF SPEAKER|red/grn - brn/blk | |radio |
| LR SPEAKER|blu/yel - gry/wht | |radio |
| RR SPEAKER|red/yel - brn/blk | |radio |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555U to bypass. *1 Also found in a 16 pin white or gray plug to the left of the fusebox. *2 In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch. *3 Also a male blade terminal is available in fuse box. *4 Looks like 14 ga.wire but mostly insulation. *5 Use both and diode isolate each. *6 12 pin blue plug on top center of fusebox. *7 Trunk release only works with the doors unlocked.
[Modified by Json79, 10:59 PM 6/30/2002]
Old Jul 1, 2002 | 06:39 AM
Default Re: CALLING ALL Electrical/Security Teg experts... (Json79)
thanks but ive already posted a link to that in a few other posts...
Old Jul 2, 2002 | 10:12 PM
philly-O's Avatar
no offense but car alarms and especially car starters should be left to the pros to install. the $100-$200 you will spend extra on the install is well worth it because of the warrenty and time of install. plus professional shops are insured meaning that if something should happen to your car they are responsible for the dammages.
Old Jul 2, 2002 | 10:17 PM
Default Re: CALLING ALL Electrical/Security Teg experts... (peichie)
No, the AG4 ran me $400....if it was a $100 difference for a quiality install and me doing it, I'd have it done. The fact is, to get one installed, the cheapest place that I would trust to do any work to my car is 900 installed. The cheapest place period is 790. Mind you those are plus tax.
I've done starters and alarms before, just nothing this intricate. There is always time for a first. But thanks for your insight.
Old Jul 3, 2002 | 11:44 PM
ImprtTunr's Avatar
Not to be an *******, but with the kind of questions you are asking you should not even be installing this yourself. If you have to ask where the easiest place is to get the window up/down wires and where to get the doorlock wires, you are in for way more than you think. It really erks me the way people take for granted the amount of skill required to do a proper alarm installation. Also, keep in mind that if and when your car starts in gear, you are responsible for all damages and if it hits a person, you are in for more than that. Also, dont forget the cost of an airbag, cause if you probe a wire you shouldnt, youre gonna be buyin new airbags and probably a new windshield also......more things that people dont consider when deciding to do their own alarm.
Old Jul 4, 2002 | 08:57 AM
Default Re: CALLING ALL Electrical/Security Teg experts... (ImprtTunr)
Thanks for the warning, however id advise on reading the thread more clearly since about an hour after I posted my first stupid intent I realized how stupid it was and then changed it.
Some cars have esier locations to access wires. I thought someone might know.
I dont understand how asking a question like that puts me in over my head.
now if i asked how do i splice a wire, that would mean im in over my head.
are you an installer yourself?
mikekh10a
Audio / Security / Video
Jun 2, 2013 01:32 PM
nineohtoo
14
Aug 4, 2009 01:03 PM
JDMCRX
May 27, 2009 12:42 PM
Outsane
Sep 11, 2005 07:28 AM
