buzzing from speakers with stereo off
Old Aug 18, 2003 | 02:20 PM
photonjedi808's Avatar
Default buzzing from speakers with stereo off
I'm getting a slight buzzing from my speakers even when my stereo is off. Anyone know how this happens? The speakers are running off a 4ch amp mounted in the trunk
Old Aug 18, 2003 | 05:41 PM
PetroGuyX's Avatar
could be a bad ground, does it sound like there's a noise when you accelerate?
Old Aug 18, 2003 | 09:56 PM
Default Re: (PetroGuyX)
it's just a constant buzzing
not like alternator whine
Old Aug 18, 2003 | 11:58 PM
TurboTeG4's Avatar
Default Re: (photonjedi808)
Ground Loop, your amp is not hooked up to the stereo remote, the stereo got on remote hooked up to the car remote, the other remote is the activation remote that activates according to whether the stereo is off or on.
Oh and make sure ur speaker wires are running away from your power wires
Old Aug 19, 2003 | 08:40 PM
SpeedDreamz.com's Avatar
Default Re: (turbocivic4)
In order for you to have noise when the radio is off, the power supply must be receiving current. EIther the amp remote lead is connected to the ign lead and still on(even when radio is off) or there is an internal short keeping the power supply in the amp active. Running wires close to other sources does not generate enough RF to cause sound from a speaker.
Old Aug 20, 2003 | 02:11 AM
Default Re: (30psiCiv)
So it might be the amp?
The noise started when I hooked up my a/f gauge
Old Aug 24, 2003 | 12:11 AM
TurboTeG4's Avatar
up, my stereo runs crystal clear but yesterday all of a sudden I got mean whine that went with my acceleration, then it went away again and its crystal clear again. Whats this about.
Old Aug 24, 2003 | 06:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic4 &raquo;</TD></TR><TR><TD CLASS="quote">up, my stereo runs crystal clear but yesterday all of a sudden I got mean whine that went with my acceleration, then it went away again and its crystal clear again. Whats this about.</TD></TR></TABLE>
You most likely have a broken ground in the radio or rca connection on the amp. Could be a pinched rca too.
Old Aug 24, 2003 | 06:21 PM
TurboTeG4's Avatar
I acutally when i hooked my eq and dsp up I just soldered my 2 ground wires to the ground wire from the stereo, so basically i soldered my 2 ground wires inline with the stereo, is this no good?
Old Aug 25, 2003 | 08:29 AM
loki2323's Avatar
I actually have the same damm problem with my car!!! Even when the radio is turned off I get this noise...and it doesn't change with the rpms...its just a constant whine
what should I do besides checking my grounds?
Old Aug 25, 2003 | 11:53 AM
loki2323's Avatar
Default Re: (loki2323)
abusedvtec
May 4, 2008 09:56 AM
Devo94ac
Audio / Security / Video
Nov 8, 2005 12:15 PM
jonoknut
Aug 6, 2005 08:06 PM
Andres-eh2
11
Jul 9, 2005 08:46 AM
agent marlon
Oct 31, 2002 12:15 PM
