Blinking alarm LED???>>>>
Old Jan 10, 2010 | 02:39 PM
EG-SIXV-TEC's Avatar
Post Blinking alarm LED???>>>>
How would I wire up a blinking LED?
Who sells these kinds of led blinking lights . i got an alarm but it dont got the led thing. I wanna also put one for my other cars without alarm just for the hell of it.
is there any DIY around, or where can i just buy one made to hook up w/bat. etc.
whats the best way
Old Jan 10, 2010 | 03:11 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Blinking alarm LED???>>>>
What color do you need. I think I have some extra units like that.
Old Jan 10, 2010 | 05:21 PM
Im looking for blue LED blinking
Old Jan 11, 2010 | 08:43 AM
bump itch ap
Old Jan 11, 2010 | 09:19 AM
mrdeadman's Avatar
They let me pick
You can get blinking LEDs from radioshack for like $1.
Old Jan 11, 2010 | 01:44 PM
crazyboy's Avatar
your local audio shop would be glad to sell u one. or 2 in ur case
Old Jan 12, 2010 | 12:54 PM
Post Re: Blinking alarm LED???>>>>
I currently got this 12V capable LED light from radio shack and right now its hooking up to my 12v battrey. i got another LED lights before and it burned. but im going to keep this type
http://www.radioshack.com/product/in...LAID=107592170
my problem is that this light particularly stays lit and dosent blink at all
is there a resistor to make it Blink and part Number???
what can i do to make it blink
Old Jan 12, 2010 | 05:01 PM
83customcivic's Avatar
Icon7 Re: Blinking alarm LED???>>>>
You can get a blinking LED:
http://www.radioshack.com/product/in...ductId=2062553
Here is what I like & recommend:
http://www.radioshack.com/product/in...ductId=2062571
(Just make sure to hide the battery pack)
Old Jan 14, 2010 | 09:43 AM
[quote=83customcivic;41219801]You can get a blinking LED:
For this type will it handle the 12volt to ground im planning on getting this and wire it to power all the time.
i did it before with this type and the 12v shorted it directly.
what resistor can i use to handle the 12v bat. pos.
Old Jan 14, 2010 | 11:22 AM
Originally Posted by EG-SIXV-TEC
Originally Posted by 83customcivic
For this type will it handle the 12volt to ground? I'm planning on getting this and wire it to power all the time.
I did it before with this type and the 12v shorted it directly.
What resistor can I use to handle the 12v bat. pos.
I have used the other link to Radio Shack I gave for the 2 AA *hidden* battery pack bright red flashing LED & it works great...in the meantime before a real alarm (hopefully the scare tactic works & they do not try)
Check www.google.com for blinking led ...much info on all kinds, types & ways to install
Here is a good example of installing a red blinking led in a car:
http://www.electro-tech-online.com/g...g-led-car.html
*Hope this helps. Search engines are the best way to find info when lost
Old Jan 14, 2010 | 01:52 PM
Thanks, but how long did it last with the 2 AA *hidden* battery powered one?
Old Jan 14, 2010 | 02:54 PM
Thanks, but how long does it last with the 2 AA *hidden* battery powered one?
About 3 months..just use good quality AA batts (Duracell or Energizer)
It is draws very low current & is very bright, so it takes a while to go completely down
Old Jan 14, 2010 | 10:43 PM
mrdeadman's Avatar
They let me pick
You can run a relay so that it only turns on when the car is off, and that will increase your battery life.
OP: You need to get the blinking LED. The one you showed in your picture is a standard LED. You can make these blink but you need to do some electronics work.
Old Jan 15, 2010 | 01:13 PM
What do i need to do if i want this particular one to blink
and what would be a good resistor that can cut power in half, i want to connect it directly to my car 12V B+ on all the time.
Old Jan 15, 2010 | 01:19 PM
If you are referring to this.. http://www.radioshack.com/product/in...ductId=2062571.. (which I think you are because I was referring to it when you quoted me).. it already has a on/off switch
OP: You need to get the blinking LED. The one you showed in your picture is a standard LED. You can make these blink, but you need to do some electronics work.
Hence I directed him here above.. http://www.electro-tech-online.com/g...g-led-car.html
Old Jan 15, 2010 | 01:28 PM
What do I need to do if i want this particular one to blink?
and what would be a good resistor that can cut power in half? I want to connect it directly to my car 12V B+ on all the time.
I have provided all the info in the links I gave..especially the "how to install red blinking led in a car" link. Read it
Old Jan 15, 2010 | 02:44 PM
mrdeadman's Avatar
They let me pick
That one has a built in resistor. I doubt you will need another one. However, you can calculate it for sure using this:
http://www.hebeiltd.com.cn/?p=zz.led...tor.calculator
The whole purpose of the resistor is to limit the current flowing into the LED, too much current will pop it.
If all else fails, I usually go with the trusty 1k. If it's too dim, then I will decrease the resistance slowly until I find a good one.
Old Jan 16, 2010 | 11:22 AM
OP: You need to get the blinking LED. The one you showed in your picture is a standard LED. You can make these blink but you need to do some electronics work.[/quote]
The one in the pic yes is not a blinking LED. What do i do to make it blink? what do i use to make the non Blinking type led blink?
Old Jan 16, 2010 | 12:30 PM
cstone's Avatar
The one in the pic yes is not a blinking LED. What do i do to make it blink? what do i use to make the non Blinking type led blink?[/QUOTE]
you dont. it will cost you the same or probably more in parts and be way harder to make a non blinking LED blink. just go to radioshack and buy a blinking LED. use a resister to drop the voltage to what you need (the LED will say how much voltage it can handle) use the link posted above to calculate the resistor you need. you have gotten all of the info you need.
if it still sounds too hard for you paypal me $25 i'll go buy the LED and figure out the resistor, solder it together for you and all you have to do is hook it to the battery. for $35 i'll throw an inline in there too so that you dont burn your car down.
Old Jan 16, 2010 | 03:23 PM
if it still sounds too hard for you paypal me $25 i'll go buy the LED and figure out the resistor, solder it together for you and all you have to do is hook it to the battery. for $35 i'll throw an inline in there too so that you dont burn your car down.[/quote]
Old Jan 22, 2010 | 07:51 AM
Special K 63's Avatar
New User
bump itch
Old Jan 22, 2010 | 11:25 AM
cstone's Avatar
why would you bump this? the question has been answered multiple times... i even offered to do it for him
Old Jan 22, 2010 | 04:10 PM
thread done, i made 1 already but yea thanks
Old Jan 22, 2010 | 11:18 PM
cstone's Avatar
glad you got it done. i was getting curious but i figured you did or you would have been back.
Old Jan 23, 2010 | 11:58 AM
thanks
knightnam
Audio / Security / Video
Jun 14, 2022 07:29 PM
baca00ex
Jul 2, 2011 02:20 PM
DB1_559
Jan 2, 2006 05:01 PM
ablack934doorcivic
Feb 8, 2005 03:49 PM
eliktronik
15
May 31, 2004 07:49 PM
