the big 3 question
Old Jan 7, 2016 | 10:49 AM
swizz977's Avatar
Default the big 3 question
hey i need to do the big 3 for my 92 civic
i have a few questions on locations
1 battery ground to chassis ground
is the oem location the best ground for this one?
2 tranny ground and chasis ground
are the oem grounds the best locations as well?
3 alternator power
this one is a little confusing
do i remove the oem wires and wire a new power to the oem fuse box and then from the fuse box to the battery?
or do i not use the oem fuse box and make my own fuse?
is there a ground for the alternator?
Old Jan 8, 2016 | 04:43 AM
swizz977's Avatar
Default Re: the big 3 question
this terminal obviously wont fit here
Old Jan 8, 2016 | 07:20 AM
MotoCARR's Avatar
3 alternator power
1. Yes add a wire from the battery ground to the chassis.
2. Clean existing grounding points, add 1-3 more grounding points from the engine to the chassis
3. Keep existing wires, run a new one from the alternator to the battery, fuse 12-14" from the battery
Old Jan 8, 2016 | 07:26 AM
swizz977's Avatar
more questions
1 i saw someone put a ground from the battery to the tranny, along with the battery to the chasis, is this nessesary?
2 the alternator power wire im leaving all the origional wires?
how can i add a power wire on top of the origional wires?
Old Jan 8, 2016 | 05:19 PM
swizz977's Avatar
i also see a few people adding a ground to the tranny to the battery ground
Old Jan 11, 2016 | 07:24 AM
MotoCARR's Avatar
more questions
1. I don't believe so. I've never done it with any big three I've done.
2. Correct. Most cars have enough room on the alternator + post to add another terminal.
Old Jan 12, 2016 | 08:56 AM
swizz977's Avatar
yea i did it everything worked great had to trim a little plastic piece on top of the alternator to fit the terminal
man what a difference that makes
also so the only ground i have on the battery terminal is to the chasis
i saw some people putting another one on to the tranny as well
might do it if i can find more wire
Le13lanc
Aug 29, 2016 06:43 AM
swizz977
10
Jan 10, 2016 05:20 PM
97civic123
Audio / Security / Video
Aug 10, 2009 09:25 PM
rick_rabies
May 2, 2009 11:24 AM
team703
Sep 14, 2004 06:30 PM
