BB6 Cd Player
Old Jun 14, 2005 | 07:14 PM
DFW's Avatar
DFW
Default BB6 Cd Player
Just wondering if a BB6 (97-01 Prelude) OEM Cd player would fit in a EG hatch and EK hatch/coupe. Would it just be a plug and play type thing or lil modification involved?
-If this is not the right forum please move
Modified by DFW at 10:27 PM 6/14/2005
Old Jun 14, 2005 | 09:33 PM
kcem1's Avatar
the cd player itself would fit but if you put in eg will need a different harness, ek 98 and up plugs right in,.
Old Jun 14, 2005 | 09:36 PM
DFW's Avatar
DFW
Default Re: (kcem1)
What harness would I need?
Old Jun 15, 2005 | 11:00 AM
fcm's Avatar
fcm
Old Fart
Default Re: (DFW)
You need the adpt. harness for your car and the rev. harness for the HU check here http://www.installdr.com, the plugs you can get at your local car audio shops. 94
Old Jun 15, 2005 | 11:02 AM
DFW's Avatar
DFW
Default Re: (fcm)
Thanks
Old Jun 17, 2005 | 07:27 PM
DFW's Avatar
DFW
Default Re: (DFW)
Oh yeah, would the cd player fit right into the old Civic spot?
Old Jun 18, 2005 | 07:18 PM
95ejjj's Avatar
Default Re: (DFW)
Bump. need to know the samething.
Old Jun 19, 2005 | 09:23 AM
fcm's Avatar
fcm
Old Fart
Default Re: (DFW)
It should there may be minor mods. 94
Old Jun 21, 2005 | 08:26 PM
95ejjj's Avatar
Default Re: (fcm)
hum I just talked to someone on here that had the cdplayer and he said it was just a direct plug and play using the civic harness. https://honda-tech.com/zerothread?id=1285696
Old Jun 22, 2005 | 06:57 AM
rjr162's Avatar
Default Re: (69.696.69.69)
IIRC it's 99 when the plug changed... so based on what I recall this is what you want to know:
up to 98 will use the 70-1720 plug, 99 and up will use the 70-1721 (Both Part #'s being Metra). if you're putting a 97 or 98 prelude radio into a pre-99 civic, it will plug right in. Same with a 99+ prelude radio going into a 99+ civic. But to put a pre-99 prelude radio into a 99+ civic, you'd need to get teh 70-1721 harness that would plug into the civic, and a 71-1720 harness that would plug into the pre-99 prelude radio, then match color for color. Same with a 99+ prelude radio going into a pre-99 civic. Get a 70-1720 harness for the civic's plug, and a 71-1721 harness to go into the 99+ prelude radio. Then match colors between the two plugs again and you're set.
Old Jun 22, 2005 | 07:50 AM
fcm's Avatar
fcm
Old Fart
Default Re: (rjr162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjr162 &raquo;</TD></TR><TR><TD CLASS="quote">IIRC it's 99 when the plug changed... so based on what I recall this is what you want to know:
up to 98 will use the 70-1720 plug, 99 and up will use the 70-1721 (Both Part #'s being Metra). if you're putting a 97 or 98 prelude radio into a pre-99 civic, it will plug right in. Same with a 99+ prelude radio going into a 99+ civic. But to put a pre-99 prelude radio into a 99+ civic, you'd need to get teh 70-1721 harness that would plug into the civic, and a 71-1720 harness that would plug into the pre-99 prelude radio, then match color for color. Same with a 99+ prelude radio going into a pre-99 civic. Get a 70-1720 harness for the civic's plug, and a 71-1721 harness to go into the 99+ prelude radio. Then match colors between the two plugs again and you're set.</TD></TR></TABLE> This is true for most Honda/Acuras, but the plugs work this way....... 1986-1997/98 same plugs on all H/A in 1997/98 they started changing to the newer plugs so 1997/98 and newer have the new plug, there is also a 3rd plug 1996 and newer on some Honda/ Isuzu 94
Old Jun 22, 2005 | 09:37 AM
DFW's Avatar
DFW
Default Re: (fcm)
Thanks, exactly what I needed to know
Old Jun 22, 2005 | 05:26 PM
t0ekn3e's Avatar
i have tested a 97 and 98 prelude hu and both fit in my eg
asocallocal
Oct 27, 2009 01:09 AM
414teg95ls
Feb 12, 2008 07:05 PM
accord03coupe
Audio / Security / Video
Oct 4, 2005 04:12 AM
User 42624
Sep 19, 2005 11:15 AM
