battery re-location wire thickness
Old Jul 10, 2007 | 02:51 PM
Flexin5's Avatar
Default battery re-location wire thickness
i was just wondering if "100 amp 3 T/W" was wire think enough for use on a battery re-location? TIA
Old Jul 10, 2007 | 03:02 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: battery re-location wire thickness (Flexin5)
not sure of that model number. what gauge is it ?
Old Jul 10, 2007 | 04:48 PM
Flexin5's Avatar
Default Re: battery re-location wire thickness (wrx-killer-Sti-eater)
aparantly it's 3 gague?
Old Jul 19, 2007 | 07:07 PM
jonshonda's Avatar
Community Builder
3 gauge will be fine!!!
Old Jul 19, 2007 | 07:32 PM
fcm's Avatar
fcm
Old Fart
Ditto that, run the 3ga from the relocated batt. to the starter motor, run an 8ga from the starter motor to the input on the under hood fuse box.
You should also "beef up" the chassis to engine ground, use 3ga to replace the stock batt. ground cable, use 3ga ground cable from the batt. to chassis, keep it as short as possible, connect to floor pan of car. 94
cubnsensation
22
Feb 23, 2018 09:11 AM
steveharrmr23
Sep 14, 2009 11:45 AM
fast90hatch
150
Oct 10, 2008 10:56 PM
shaggyeg6si
Jun 18, 2008 06:46 AM
4DRmafia
23
Oct 10, 2005 07:36 PM
