backup battery replacement
Old Aug 23, 2010 | 09:56 PM
yessewey's Avatar
Default backup battery replacement
well as the title states i was wondering about a backup battery replacement since i've read there have been so many issues with the battery that comes with the DEI 520T, will another 12 volt battery with 1.3Ah be sufficient to replace it? any other input u guys have would be great thanks
Old Aug 23, 2010 | 10:14 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: backup battery replacement
If your on a budget use the dei battery till it fails then replace. If your doing a full stealth install were you removing the dash its better to swap it now. I used that size battery and it will charge fine. I been trying all kind of batteries till I can find the one that will work better. I have a couple of members letting me use there alarm setup as text car. So in the next couple of months I will update my thread I started. Best thing to do is full charge the battery before you install it. That helps out alot with any battery. If you don't have a charger. Drive the car for a hour or let it run in the driveway or where ever for 30 min.
Old Aug 24, 2010 | 08:21 AM
yessewey's Avatar
nah im not on a budget just that i noticed when i disconnect my car battery i tried to disarm my alarm and i got the out of range beep from it so yeah i figure its time to upgrade. i saw some bigger batteries but with a much larger Ah output but i just wonder where i would place them.
Old Aug 31, 2010 | 01:52 PM
EnjoyTheRideDC2's Avatar
I wouldn't go much larger than a 12V 1.3ah lead acid for a backup battery.
Old Sep 2, 2010 | 10:05 PM
This is the battery that I am getting the best results with.
Old Sep 22, 2010 | 11:01 AM
Graceygirl's Avatar
where did you guys put the battery? I just got one, and am not sure where to place it....
Old Sep 24, 2010 | 09:05 AM
yessewey's Avatar
the one i got isn't too much larger than the one that comes with the 520t so i put it along with the brain of the alarm, as long as you have the brain hidden well there should be no worries because if a thief finds either item then you're screwed regardless.
Audio / Security / Video
60
Feb 19, 2013 07:42 PM
pepebuho
Jun 9, 2007 05:45 PM
BlackThorN
15
Jun 27, 2004 01:31 PM
