Back Up Camera
Old Aug 30, 2016 | 04:31 PM
kitt1993's Avatar
Default Back Up Camera
Hello everyone,
I am in need of wiring diagram information. I have a 2015 Honda Accord that I am working on. I would like to check the voltage at the back up camera connector and continuity for the video wires as well. I had a friend look it up on All data and Mitchel On Demand. There's nothing there. Does any one know what voltage the camera operates on? Which wires are what? Here below is a list of the wires and colors
Black
White
Yellow
White
Black
Red
Appreciate any help
Bryan
Old Aug 31, 2016 | 01:57 PM
fcm's Avatar
fcm
Old Fart
Default Re: Back Up Camera
If it is OEM then I should be available at Mitchel on demand, if it is an aftermarket camera, [dealer installed] plugged into a stock system, you may be able to get that info from the manufacturer.
A pinout of the plug/socket on the back of the stock unit would also get you the info you need.
All I can tell you is the voltage is most likely 12V+ with a common ground, [chassis ground].
But if you do a continuity check on each lead and have good continuity on all, [when plugged in] a ground, [full chassis continuity] and at least one 12V+ source, [with IGN. on and in reverse] and unit does not work, my guess is the camera itself is the problem, but could just as well be in the HU, [but less likely if everything else works on the HU. 94
Old Aug 31, 2016 | 02:33 PM
kitt1993's Avatar
Hello,
Yes, it is a factory camera. When I had Mitchell On Demand print out, all it shows was the wires coming from the radio to camera. And the colors. But not what wire is what or voltage, ohms, etc....My friend there at the shop said import cars are like this and don't give out that info. Should I have him took up the radio and pinout instead of the camera diagram?
Thanks
Bryan
Old Aug 31, 2016 | 02:43 PM
fcm's Avatar
fcm
Old Fart
Then you will have to get the radio pin-out. 94
Old Sep 4, 2016 | 07:15 PM
kitt1993's Avatar
I had him look it up and there's nothing there but the color of the wires. It doesn't tell me which one is power ground video or audio etc.
Any suggestions?
Bryan
LuckyStrike90
Feb 15, 2018 01:42 PM
suno
Apr 14, 2008 06:02 PM
DougP
Audio / Security / Video
Mar 2, 2006 02:07 PM
98R-1144
Sep 8, 2002 07:24 PM
