Audio/Sub help
Old Apr 10, 2004 | 02:18 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Audio/Sub help
We just hooked up a sub in an EG Civic with a Pioneer head unit. The sub is only putting out high frequency. Any idea as to why it's doing that? We've installed many subs and never run across this problem. Any incite is much appriciated. Thanx guys.
Old Apr 10, 2004 | 02:42 PM
john666's Avatar
Default Re: Audio/Sub help (Hatchy-Ownzjo0)
Does your amp have a built in crossover ? Or do you have a crossover hooked up ?
Old Apr 10, 2004 | 08:14 PM
ShaunRR's Avatar
HT White Ops
Community Builder
You dont have a crossover or it is not turned on. If it is on, then you have it on high pass and not low pass like you should. You didn't mention what kind of amp you were running. Please tell me you are not running your sub off of the deck amp.
Old Apr 12, 2004 | 07:10 AM
spark plugs.
Guest
Posts: n/a
Default Re: Audio/Sub help (rochesterricer)
we need more specs man!!!
Old Apr 12, 2004 | 07:45 AM
AndyGCT's Avatar
which headunit is it??? Pinoeer has a option to turn off the subs...Be sure the RCA'a are hooked up to the SUBWOOFER OUTPUT.
THEEENNN on the headunit, push the Audio button till SUBWOOFER comes up on the screen
Then push UP button to turn it on...
THEENNN push the audio button again, and change the subwoofer freguency by pushing left and right and change the volume output by pushing up or down... I keep mine on 80hz to play all ranges below 80
The head unit has a HPF selection which is the high pass filter, turn that on by pushing up and then left to 80hz, that way no bass below that range is going to the internal speakers...
good luck but dude we need more specs on the headunit, what amp youre running, how many RCA outputs are on the thing aaannnddddd how many subs ya got...
Old Apr 12, 2004 | 10:07 AM
H-T Poker champion
Default Re: Audio/Sub help (AndyGCT)
It's a Pioneer 5600(i think) Head unit. It's a Pioneer 400Watt amp. It's a 400Watt 8 inch sub.
Old Apr 12, 2004 | 01:39 PM
AndyGCT's Avatar
well 5600 isnt a pioneer type but if you have the 6600 you should be good to go, follow my instructions. The radio on the back has 3 RCA jacks, one for FRONT one for REAR and one for SUBWOOFER...They have the tags right on them so its not that hard to figure out what is what...Give it a whirl and get back to us....
Old Apr 12, 2004 | 03:51 PM
H-T Poker champion
i know how to install a sub.. i also know how to work the cd player. we took the car to an audio shop and they didnt know why it was doing it. the only thing we can come up with is that the head unit sub output is going bad.
Old Apr 19, 2004 | 09:51 AM
Archidictus's Avatar
Unceasing Measure
It's my car that is being discussed here. The amp is fine, the sub is fine the headunit has bad RCA outputs. Horseshit for Pioneer, but whatever. I guess I won't be rocking a subwoofer. Not a big loss .
Old Apr 19, 2004 | 12:09 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: Audio/Sub help (Archidictus)
Don't let that sway you from getting another Pioneer. They are by far the most resiliant and reliable decks out there. With sophisticated electronics sometimes **** happens.
rountreesj
Audio / Security / Video
Dec 18, 2012 06:51 PM
ekcivic9
24
Jan 20, 2006 08:41 AM
Iomega01
Aug 27, 2005 09:54 AM
blindO
May 30, 2005 07:21 AM
